Roadster Seat or Pedal adjustment
Nariko
New Member
Mar 20, 2014
4
0
After years of drooling, I might be close to pulling the trigger on getting a Tesla Roadster. I have one major concern, though. I am a 5'0" tall woman, and I when I have driven roadsters, I have had a hard time being able to depress the accelerator all the way. I have the seat pulled as far forward as it can go, and it is right at the edge of what I can reach. Has anyone else run into this issue, and is there anything that I can do about it? Any thoughts or ideas are appreciated.
PV4EV
559
709
Area 51(a) / UK
It should be possible to have the seat runner adjusted / modified so that the seat is a bit further forward.
Oddly enough I had the opposite problem when considering a purchase years ago .. and had to ensure that the seat would go as as far back against the bulkhead as possible.
hcsharp
3,370
1,337
Vermont
I've seen rubber pedal extenders like dhrivnak mentioned for sale with different heights but I can't remember where I saw them. If you search I'm sure you can find them. With the seat all the way forward, is the steering wheel close enough? You might want to consider PV4EV's solution to get the right steering wheel distance, and then use the pedal blocks to get the pedal adjustment correct. You might be one of the few Roadster owners who actually uses the driver's side sun visor! Good luck and welcome to TMC!
Jackyche
319
2
Seattle
When you said, "when I have driven roadsters", did you mean, other roadsters (2-seater convertibles) or did you mean specifically Tesla Roadsters?
I ask because, I'm 5'3" and I do not have the seat all the way front. It has the best driving position of any car I've ever owned and ironically the seat only goes forward/backward versus the Mercedes SL500 I had that had a 13-way power adjust that I didn't seem to be able to find the perfect position.
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Height isn't the only factor. People who are the same height can have very different torso and leg lengths. (On average men tend to have longer torsos, and women tend to have longer legs, but individual variation is probably greater.)
I'm only 5'10" but I'm kinda too "tall" for the Roadster. I can't read the speedometer and had to remove the sun visor so I could see out. If I am wearing a helmet (for autocross/track) I have to use the soft top; it won't really fit under the hard top.
EVsport
35
0
Northern VA
Nariko, Do it right the first time and it will make your driving experience much more enjoyable and safer. Have the lower seat rails moved forward to compensate the distance, they can always be moved back.
