Roadster Test Drive: Steering Wheel shake at freeway speeds
Discussion in 'Roadster 2008-2012' started by FutureOwner, Jul 28, 2015.
Tags:
  1. FutureOwner
    FutureOwner Member
    Bay Area, CA
    I recently test drove roadster #116 and noticed fairly violent steering wheel shake at freeway speeds. Is this normal for the roadsters?
    My initial thoughts are the wheels aren't balanced correctly as the car was still responsive, wasn't shifting in the lane and the shake went away when I reduced speed.
  2. josh-io
    josh-io Member
    San Jose, CA
    Hi FutureOwner, I also test drove #116 (red and black!). In an odd stroke of coincidence, I ended up buying #117, which has 5,000 miles compared to #116's 8,000. I too noticed the severe steering wheel shake on #116, which I don't experience with my roadster. Everything I've read is that it's a temperamental but correctable problem:
    Vibration through the steering wheel
  3. Habious
    Habious Member
    Springfield, VA
    I've driven 2 Roadsters (mine - #1195) and another that I test drove when I was shopping (don't know the number).
    Neither of them exhibited what you described. Mine is absolutely rock-solid at freeway speeds. The steering feel in my Roadster is second-to-none.
  4. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    Mine did that when I got it. I had the service center check it out, and they told me to replace the front tires. Once I did, everything smoothed out. I'm not sure if it was a problem with the tires or if balancing fixed it, but I like the new tires better anyway.
  5. strider
    strider Active Member
    NE Oklahoma
    supersnoop is right. Roadsters are very sensitive to tire balance. Have the owner get the tires balanced (or replace them) and then drive it again. That's likely all it is. But if after that there's still a problem then don't buy it :)
  6. FutureOwner
    FutureOwner Member
    Bay Area, CA
    Thanks for the helpful information! I'll ask them about the front tires.
  7. GVTesla
    GVTesla Member
    Netherlands
    I've experienced the same when the roadster had sit for a longer time in the garage. She was fine when I parked her and it slowly went away after a 50km drive. Somehow suspect that the Yoko's (being a very rigid compound) take some time to get back in their nice round shape.
    Then again, in your case it also might be uneven wear of the tires or the wheels needing some balancing or maybe the front train needing some aligning.
  8. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Very likely one or more tires is out of balance. Roadster steering feel is normally quite good. Is #116 for sale and you are considering buying it?
  9. augkuo
    augkuo Member
    Berkeley
    I got #970 with a bent wheel - that's most likely causing the steering vibration.
  10. tvuolo
    tvuolo Supporting Member
    Colorado
    I had an issue with my rear tires making a ton of noise and vibrating at higher speeds. I took it to the tire shop to get the tires balanced (making sure they wouldn't put it on the lift). It turned out that my tires were very old, from 2009, and were wearing funny. They suggested I just get new ones. So I took #265 to the track and did my best to destroy the old tires, which is a LOT harder than it sounds - the car is so dang sticky! I picked up some new tires from Tirerack and had my shop install and balance them. Now it's as quiet and smooth as can be!
  11. richkae
    richkae VIN587
    I would assume that if the car has had that shake for a while, even after the tires are fixed it will be in desperate need of a proper wheel alignment.
  12. TEG
    TEG Teslafanatic
    Many things can cause freeway vibration. Losing a balancing weight on a wheel. Flat spots on the tires from sitting too long. Uneven lug nut tightening (may cause shake under braking due to rotor warpage.)
    It is usually a relatively minor problem that can be corrected. Hopefully nothing is really messed up with the suspension on that car. Suspect tire flat spots due to sitting too long...
    The Roadster's manual steering transmits road feel very effectively. So, when something isn't right you really feel it.
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Roadster has such direct steering that even the slightest tire imbalance comes through the steering wheel. The tires can and do go out of balance just due to wear. I get my fronts rebalanced whenever I change my rears, which are replaced 3X as often. Even then I sometimes get steering vibration before the rears wear out again.
    So 98% likely it's just tire balance.
  14. simonog
    simonog Member
    United Kingdom
    I race (a Morgan) on Yokos and they are a fantastic tyre. I would not, however, use tyres more than 2 years old as they harden especially if left in daylight.
    i am running new Yokos on my 9,000 mile Tesla Roadster and they are excellent. Some people worry about the grip in the wet: if you are gentle on accelerator and brakes they seem fine to me.
    Steering judder at 50-70 mph is nearly always due to front wheel imbalance. The chance of its being suspension is much lower.
  15. ecarfan
    San Mateo, CA
    In an emergency situation when you need to stop quickly you clearly cannot be "gentle" on the brakes.
    Exactly which Yokohama tires are you using?
  16. supersnoop
    Pflugerville
    I will note that I had the terrible vibration with the A048's on the front (the 195 width tires), and switched to the AD07's (at 175 width) and the ride improved dramatically. That could just be because the A048's were old and/or out of balance. But they are a wider, stickier tire.
  17. Doug_G
    Ottawa, Canada
    A048's wear faster, so you are likely to get the vibration sooner.
  18. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    When I got my tires there is a yellow and red dot. I "think" yellow is the light spot and red runout. One (yellow I think) is to be lined up with the valve stem and they got it backwards and I had a noticeable vibration above 45. They remounted and the weights went from like 3.5oz to 1.5 oz and now the ride is smooth. So it is likely a simple mounting and balancing issue.
  19. simonog
    simonog Member
    United Kingdom
    I use the 048s and find them to be excellent.
    As they are quite soft, however, you can flat spot them quickly if you lock the car up and then yes, they will feel similar to unbalanced wheels.
    Braking in the wet is surely the same with any tyre type: the laws of physics will apply and when stopping force exceeds friction grip available, either ABS (automatic or manual) operates or car locks at least one wheel. I tend to use cadence braking (rapid repeated pushes on the brake pedal) to stop the car. One of the worst things about locking up front wheels is that steering goes as there's no spare friction. It took me a while to train myself to come off the brakes enough to restore steering when that happens (in the hope of avoiding any incident). I just find the 048s as good as anything, and they don't "snap" (ie if they do let go, it's progressive).
  20. djf
    djf Member
    Santa Rosa, CA
    I recently bought #243. It is rock-solid at speedway speeds, no shake. So something's up - hopefully easily correctable - with #116.
