Roadster VDS Messages
Discussion in 'Wiki' started by Slackjaw, Aug 31, 2012.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. BartJ
    BartJ early member
    Belgium
    added info on #1463
    This problem appeared to me after a yearly service because the HVAC was overfilled. Check HVAC fluid level
    Added info on #1144 and #1146
    Probably the PEM/Motor fan needs to be replaced.
    Also check the connectors or wiring between the fans and the PEM. Could just be a bad contact
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    ID:1535 Data:0x00000080
    VMS: Linux kernel version doesn't match car-wide release.
    ID:887 Data:0x00000080
    Can't start Version number mismatch.
  3. Slackjaw
    Slackjaw Member
    Central NJ
    Hi, I'd like to add some notes to error ID:287 "Powertrain Problem / Service Required" which came up yesterday after I had been driving in fierce rain and been loading the trunk earlier in the same rain, then tried to charge when I got home. The car would drive but not charge. I did put a call in to Tesla Motors and haven't heard back but I asked Michael Thwaite for advice; he explained it was probably water etc., which is exactly what it was, so I left the car out in the sun for 2-3 hours and the problem went away. Amazing really.
    So whoever can edit the original post (I can't): Notes field can say something like "Confirmed that in one Roadster 2.5 case, this problem was probably caused by water and was definitely resolved by baking the car in the July sun for a few hours with doors, trunk and charge port open, after which the car went back to charging normally."
    Thanks! -- Ian
  4. Saftwerk
    Saftwerk Member
    Bavaria
  5. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Renamed this wiki thread since it really is primarily about Roadster VDS messages, rather than a general Roadster wiki. Other things like a Roadster FAQ or Roadster History should be their own threads.
  6. Stefan T
    Stefan T Member
    Sweden
    I have got ID:58 and that's missing in the table
    VDS says following:
    ID:58 TPMS: No data fault
    Data 0x00000100
  7. Roeland54
    Roeland54 New Member
    Belgium
    I have got some debug messages for the list:
    ID: 257 red “APS output 1 (main) reset”
    ID: 1562 orange “VMS: Not receiving GS version number”
    ID: 1559 orange “VMS: Not receiving HVAC version number”
    ID: 1558 orange “VMS: Not receiving TCM version number”
    ID: 1522 orange “SWP: BPS Active”
    ID: 1131 yellow “DMC FW: Lost Comms With Shifter”
    ID: 1098 orange “DMC FW: Lost ABS Comms (and TC) warning”
    ID: 63 orange “GS: No data fault”
    ID: 61 orange “TCM: No data fault”
    ID: 54 orange “HVAC: No data fault”
    ID: 1661 yellow “PM: Gear Selector Comms Warning”
    ID: 58 orange “TPMS: No data fault”
    Is there a place where I can find an explanation for the abbreviations?
  8. PV-EV
    PV-EV Member
    Alaska
    I think I can help with some.
    TPMS tire pressure monitoring system
    HVAC heating ventilating air conditioning
    TCM traction control module
    BPS backup power supply
    SWP switchpack
    VMS vehicle management system
    APS auxiliary power supply
    If you are experiencing these you may have lost your APS power to the PEM.
  9. PV-EV
    PV-EV Member
    Alaska
    A couple more
    GS gear selector
    PM pedal monitor
  10. rambo1964
    rambo1964 Member
    Close to Hamburg
    Hi everybody,
    I got a new failure displayed.
    HVAC: Coolant Pump OverCurrent. ID1441
    press to dismiss works, but it comes up again after a while.
    Any suggestions what to do or how to repair?
    Thanks, Frank
  11. dpeilow
    dpeilow Moderator
    Winchester, UK
    Anyone know what error 104 is?
  12. doug
    SF Bay Area
    Given that 101, 102, 103, 105, 106, and 107 all say "Parking System Service Required", I'd say your wiper fluid is low.
  13. dpeilow
    dpeilow Moderator
    Winchester, UK
    Funny thing is that showed up on OVMS twice but not in the car. There were no obvious parking system issues when I drove it too.
    However I have a new one to report: ID: 1130 "DMC FW: VBUS Present With ILOOP Open". Anyone have a clue that what is about?
  14. dpeilow
    dpeilow Moderator
    Winchester, UK
    My Roadster is in the service centre at the moment. They obviously finished the service this morning. When the OVMS came back to life I saw two lots of 1560 (two minutes apart) and then two minutes later it sent 1163. None of those are in the top post here. Any ideas?
  15. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    1560 VMS: Not receiving IP version number
    1163 ?
    The 1560 is probably just because something wasn't plugged in, being updated, or something like that. Not to worry about, if it went away. No idea about the 1163.
  16. stephenburns1
    stephenburns1 Member
    Great share! Thank you.
Thread Status:
