Roadster Window Shade ideas
Discussion in 'Roadster 2008-2012' started by wiztecy, May 20, 2012.
Tags:
  1. wiztecy
    wiztecy Active Member
    #1 wiztecy, May 20, 2012
    Roadster Window Shading Ideas
    I discovered that the roadster's cabin heats rather fast when sitting outside on sunny days due to its compact size. I purchased at my local automotive store a two piece front window sun protector that works perfectly on the roadster. The two piece is key and it tucks behind the seat very well when folded. Next I had to find a side window shading solution. I ordered off amazon.com a retractable "dreambaby" window shade: Amazon.com: Dreambaby Wide Car Window Shade, Black: Baby
    This was the only shade I could find that had a similar width to the roadsters.
    This also works fantastic as well and also tucks behind the seat in a very compact manner. It mounts to the window with two suction cups that actually work and don't loose their cling which is good. Both of the above solutions greatly reduced the cabin temperature when out in the sun and inexpensive as well. I may pick up another side window shade to avoid switching sides throughout the day as the sun passes over. I believe Amazon sells the two pack of the side baby shades as well, don't know if the dimensions are the same as the single.
  2. vfx
    vfx Well-Known Member
    CA CA
    My car's a dreambaby too!
  3. tennis_trs
    tennis_trs 2010 2.0 Roadster Sport
    Thanks for the info; recently I've been thinking about finding a good way to block most sun from the interior when parked.
  4. daniel
    daniel Active Member
    Kihei, HI
    I see you have the hard top. When I come back to the car after it's been parked in the sun on a hot day I just take the cloth top off. I also have the Taylor mesh top for use when appropriate. (Hot sunny days when there's ZERO chance of rain, if we're talking about leaving it parked, or any time I'm driving on a hot sunny day.)
  5. strider
    strider Active Member
    NE Oklahoma
    I have the solarguard windshield and aftermarket tint on the side and rear windows. Keeps the heat down pretty well (although I don't live in a really hot place). I'll dig up specifics for you tint thread.
