I might have missed it but what was the 0-60mph time?
They didn't measure that. They did 1/4 mile time and top speed at 1/2 mile.
Negative 0.24 seconds, based on a top speed of 176km/h (and being generous with the 60mph to 109mph acceleration).
In order for the math to work, Doug must have travelled back in time off the start line, emerged from the time warp at 60mph and accelerated up to 109mph over the quarter mile. Now that's an impressive launch!
You can't do a linear extrapolation. The Roadster's acceleration falls off a cliff above 150 kph. By 170 kph it's down to 12%. At 180 kph it's down to 5%.
From that you can see that the 0-60 might have been 3.2's give or take !!
Read back through the thread. I think they key is their timing method at this event. They had some kind of rolling start so a chunk of the normal driver reaction time and normal "hook up" time was not part of their measurement. You wouldn't want to compare these times to something done a "traditional" NHRA/NEDRA type way...
(Doesn't really answer things, just provides more data...)...
A Few Words About Rollout
The term "rollout" might not be familiar, but it comes from the drag strip. The arrangement of the timing beams for drag racing can be confusing, primarily because the 7-inch separation between the "pre-stage" and "stage" beams is not the source of rollout. The pre-stage beam, which has no effect on timing, is only there to help drivers creep up to the starting position. Rollout comes from the 1-foot separation (11.5 inches, actually) between the point where the leading edge of a front tire "rolls in" to the final staging beam — triggering the countdown to the green light that starts the race — and the point where the trailing edge of that tire "rolls out" of that same beam, the triggering event that starts the clock. A driver skilled at "shallow staging" can therefore get almost a free foot of untimed acceleration before the clock officially starts, effectively achieving a rolling-start velocity of 3-5 mph and shaving the 0.3 second it typically takes to cover that distance off his elapsed time (ET) in the process.
We believe the use of rollout for quarter-mile timed runs is appropriate, as this test is designed to represent an optimum drag strip run that a car owner can replicate at a drag strip. In the spirit of consistency, we also follow NHRA practice when calculating quarter-mile trap speed at the end of the run. So we publish the average speed over the final 66 feet of the quarter-mile run, even though our VBOX can tell us the instantaneous speed at the end of the 1,320-foot course, which is usually faster.
On the other hand, the use of rollout with 0-60 times is inappropriate in our view. For one, 0-60-mph acceleration is not a drag-racing convention. More important, it's called ZERO to 60 mph, not 3 or 4 mph to 60 mph, which is what you get when you apply rollout. While it is tempting to use rollout in order to make 0-60 acceleration look more impressive by 0.3 second, thereby hyping both the car's performance and the apparent skill of the test driver, we think it's cheating.
Nevertheless, some car magazines and some automobile manufacturers use rollout anyway — and fail to tell their customers. We've decided against this practice. We publish real 0-60 times instead. But in order to illuminate this issue and ensure we do justice to every car's real performance, we've begun publishing a clearly marked "with rollout" 0-60 time alongside the primary no-rollout 0-60 time so readers can see the effects of this bogus practice...
Posted on August 3, 2012
In addition to two radar guns at the half mile, a timing system will be used to clock times on the first .25. Should make for some interesting stats.
Roadster 1/4 times:
- A timing light system recorded the first quarter mile. The timer started when the first beam was broken by the vehicle
- Some vehicles did not break the quarter mile finish beam for long enough to stop the clock and therefore no quarter mile time was recorded. This happened mostly with the bikes. Sorry guys! We will raise the beam by 12 inches next time so that more of your body breaks the beam. We will need your help in the spring to test this.
#413 Tesla Roadster 10.39
12.664
12.651
Notice, of the 3 runs, two were very close, (and seemingly more realistic) 12.6xx times, but then the one outlier 10.39
Sorry to say it, but perhaps a timing clock malfunction?
