Rolec charger filled with water
NigelT
93
35
UK
Just found the adapter plug(?) on my charger after the recent heavy rain in S Yorkshire area. I don’t have the car yet and The charger is just as the installers left it. The cable was looped over with a “weather proof” cap on the end, resulting in the cap filling with water ‍♂️
I’ve got it all drained and dried out, any tips for giving it a clean? It looks a little - I stress, a little bit dirty in there, although I also never really looked at it before. Tried some cotton buds didn’t really do much though.
I’ve clipped it onto the port on the front of the wall unit now so that water cannot collect again.
WannabeOwner
5,758
2,893
Suffolk, UK
If its the one I think it is then its a dust cap, not a waterproof cap. Dangle it over the cable-tidy, with the plug hanging down so no water can collect, and keep the dust cap off it. Water collecting in the plug will erode the pins over time; they will be fine "in air" (but hanging down) (Although i think some Rolec wall charger have a fake-socket in the front that you can plug into when not in use - hopefully that has a drainage hole!)
I have a spray can of electric contact cleaner for cleaning my charger plug ... but I've read conflicting advice along the lines of "cleaning is not a DIY option"
Adopado
3,294
2,457
Scotland
Caps on cables have been reported as having this problem several times on this forum. Seems best to either leave cap off and dangle downwards or keep plugged into a retaining socket, as you are doing. I have no previous experience ... but ... I would flood it with WD40 to flush any bits of grit or whatever, dry off the residue with paper towel ... hopefully sorted. I'm sure someone will post a reply telling you WD will kill your charger if this is a known problem!
Adopado
3,294
2,457
Scotland
Yes, I would need some serious convincing to believe that using proper electrical contact cleaner could cause any problems.
Glan gluaisne
2,782
2,688
UK
The main problem with using contact cleaner on the plug/socket bits is that it tends to attract a lot of dirt over time, due to the protective residue it leaves behind. I'm not a fan of using it on connectors that are left outside, for that reason.
