FWIW, all those Rolec units that do not have a Type B RCD, and which were installed with the aid of grant funding, were never compliant. Long before the regs were amended to include EV charging, in Section 722, almost the same wording was in the spec for all grant aided charge point installations. Rolec, and a few others, chose to ignore this, most probably because Type B or Type EV RCDs were expensive. Doesn't excuse them, though, they still broke the rules. IIRC, the requirement for a Type B/Type EV RCD dates back to around 2012/2013, so all grant aided charge points installed after that date should have been compliant. Rather bizarrely, because what's now in Section 722 of BS7681 wasn't actually included in the regs themselves back then, and was a separate note, it didn't apply to any non-grant aided installation. All a bit bizarre, when you consider the risk.
As for the crap Chinese components Rolec use, there's evidence that even the newer, RCBOs, the green writing ones, can burn out. The ones with the blue writing were universally crap, dozens, perhaps even hundreds, of them failed, some coming close to starting fires, as the photo below shows. Best bet is to replace a duff one with a decent brand, i.e not cheap Chinese tat.
