Rolling from R to D
DopeGhoti
1,210
1,373
Phoenix, AZ
The manual explicitly states that you can shift into Reverse if the car is moving at less than 5 MPH; and that you can shift into Drive if the car is moving at less than 5 MPH in Reverse.
It does not state that it's a good idea.
Reactions: shiftkenny
JulienW
2,521
2,738
Atlanta
....Also it is software controlled so if you pass the 5MPH threshold it won't switch. Plus it is NOT a gear or any mechanical switching. it is just the motor going in the opposite direction
Reactions: raptor5244
p-f-g
116
124
Switzerland
No issue at all. But be careful that after switching, the car will continue in the same direction until you press the accelerator again.
Tha_Reaper
89
46
Belgium
You don't need to. Just waiting will eventually make the car go the other way after 2-3 seconds. If you have the space, it's no problem. Just don't try it when you are rolling towards a wall...
gcmak
208
180
San Francisco
This is why I turn on creep mode...mimics a normal torque converted automatic a bit more...and in practice reminds me of a standard dual clutch transmission.
WhiteSpeed
11
10
Hayward CA
I use this all the time. Backing out of a garage or parking space, just flip the shift lever, stab the pedal and go! This is not a problem for the motor, or drive electronics. As mentioned, no switching of gears involved. One should be cautious that you don't accidentally back into something during that split second between shifting and forward motion.
StealthP3D
8,629
63,226
Maple Falls, WA
I know on an ICE this is bad to do. It seems easy to do on our cars, how bad is it to go from R to D while the car is still rolling back a little.
It won't hurt it but it's more efficient to use the brake to come to a stop before changing directions. Electric motors are not very efficient at very slow speeds and you are essentially using the motor and batteries as a brake.
