Roof Rack for the M3
Discussion in 'Model 3' started by dbog, May 28, 2016.
Tags:
  1. dbog
    dbog New Member
    So Cal
    I was pricing out a Tesla S prior to the unveiling of the M3 and was dismayed that the roof rack's associated attachment points are only available with the panoramic roof option. As I will be using the M3 here in So Cal and it can get a bit hot in the summer, I was planning on not ordering the panoramic roof as an option in order to keep the interior cooler, but I would like to be able to attach a roof rack for bikes and surf boards. Does anyone know if there will be a provision for the roof rack on the non-panoramic roof?
    Thanks
  2. S'toon
    S'toon Knows where his towel is
    AB
    Nobody outside of Tesla knows those kinds of details yet. Anything anyone says at this point would be pure speculation.
    Edit:
    Oh, and welcome to the board.
  3. dbog
    dbog New Member
    So Cal
    Thanks for the quick reply. Go Rough Riders! Is there any evidence that Tesla follows these forums?
    • Disagree x 1
  4. Tiberius
    Tiberius Member
    SoCal
    Absolutely not.
  5. Colsla
    Colsla Member
    Vancouver, BC, Canada
    I've never owned a car with roofrack, so I am not sure if I wanna go for sunroof and get roof rack option (if offered) 'just in case.' It would be nice if the options is offered with both glass and sunroof options.
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    There is evidence that Tesla reads TMC posts.
    As to a Model 3 roof rack, @S'toon is correct. TMC members have no information about that. But that won't stop the speculation.
    I expect that the 3 will be like the S: if you want to be able to mount a roof rack you will need to get the sunroof option. But I am only speculating...
  7. pedriscoll
    pedriscoll Active Member
    Indianapolis, Indiana
    Except for cost, there is no reason not to get the Pano roof. You get more headroom, the large roof is nice to open on mild days and it really does not make the car heat up. I had no trouble last summer even when temps were in triple digits. It also really impresses your passengers.
  8. dbog
    dbog New Member
    So Cal
    I'm in agreement with the bulk of your comment other than I'm not a particular fan of sun roofs; convertibles, yes but not sun roofs. I'd rather not spend money on options I don't want or find value in. It would be nice if one were able to spec the M3 to one's preference without the need to spend money, in this case, just to be able to mount a rack to carry my surf board. As this is the electric car for the masses, I hope Tesla is taking this into consideration. We don't all want fully optioned cars. I'd really rather spend my money on additional range.
  9. S'toon
    AB
    Spoken like someone who hasn't experienced a cold winter. It may not make the heat up, but it does radiate in cold. We get down to -35, -40 degrees here in winter. We need all the preservation of heat in a car we can get.
  10. gregincal
    gregincal Active Member
    Santa Cruz, CA
    Actually, I've never understood why it's that way on the S.
  11. Colsla
    Colsla Member
    Probably. Part of bundlung up of options to make manufacturing simpler and kind of forcing People to upgrade to get more revenue I assume
  12. etm33
    etm33 Member
    Buffalo, NY
    Given the numbers of Model 3s soon to be on the roads, I'd guess that third-party rack makers (Yakima I think is the OEM for the Model S rack) will accommodate the demand if Tesla won't. Though it won't be as easy to do the "clips and towers" type, since the door is frameless :(
  13. Autolycus
    Autolycus Member
    ATL
    It's not the outside temperature that causes the car to heat up with a big sunroof. It's the IR energy from the sun. You're in central Indiana. The amount of solar insolation in your area is about the lowest in the lower 48. A glass roof can make a big difference somewhere like Georgia or Florida and a REALLY big difference in Arizona, NM, and southern Nevada/SE California.
  14. Nuclear Fusion
    Your mum
    I want the option of carrying stuff on top of the car (hang glider, timber, etc) so sun roof is my only choice
