If your concern is the effect on the range, I saw some videos, I think from i1Tesla,Is the roof rack intended to be installed when needed? Or is it a bit more permanent?
I measured the roof racks and couldn't see how they would fit in the back. I agree that they aren't "easy" to get on and off but you can do it in 10 minutes or so. What I have noticed though that I don't like is that the wind off of the roof racks make a whining noise at around 40-50mph. I haven't driven on the highway yet with them but I'll have to make a point of hitting 60+ somewhere and I'll report back.If your concern is the effect on the range, I saw some videos, I think from i1Tesla,
testing the effect of the roof rack on the energy consumption and it was not noticeable.
There was even a test with a smaller lower consumption with the roof rack.
But if you have some accessories installed on top of the rack, like for snowboard,
then it might be advisable to remove the accessory or the full rack if simpler.
Note: In the case of the model 3, you cannot easily put the rack into the trunk
because of the width of the trunk, so you need to fold the rear seat to carry them.
However, I wonder it it is possible to carry them in the Model Y trunk, because the Model Y
provides some room on both side behind the wheelhouse, so you could carry them
inside the trunk parallel to the rear bumper?
Based on the install steps it doesn't seem like something you would want to remove and install as needed.
As I say below, it's easier than any other removable roof rack I've had. Here's a quick run-through of how to attach the rack, in case you don't want to sit through a 10 minute video in which the first minute is spent making the same penis joke multiple times. (I gave up at that point myself.)
I'm still gonna be nervous about placing those 2x4s on the rack, and taking them off. And making sure my tie-downs don't slip and crash into the glass. But this is an SUV, dammit! I'm gonna utilize it.
OMG this is amazing. Thank you so much. That was the clearest photo/description steps I've seen.
It looks like it's something that I can take on/off when needed, rather than having it permanently on.
I don't expect to put it on/off daily, just when I know a trip is coming up and I'll need it. This seems simple enough. I only worry that after awhile, that cover will get loose from all the prying on/off.
I just posted my experience with platform bike racks, and will be reverting back to roof racks. At least I know what to expect when the inevitable happens.Just be careful to remember that you have something on the rack if you enter a garage. Else this could happen....
Sheesh.
Has anyone seen any information on how much of a range hit you get when you add a roof top storage box?
I'm not talking one of those old white boxy ones from Sears ... something relatively modern and aerodynamic.
Thank you for the pictures and instructions. Well done.As I say below, it's easier than any other removable roof rack I've had. Here's a quick run-through of how to attach the rack, in case you don't want to sit through a 10 minute video in which the first minute is spent making the same penis joke multiple times. (I gave up at that point myself.)
Slip the weatherstrip retractor under the weatherstrip and retract it:
Slide the hook under the retractor:
Jiggle the hook a bit to make sure it's centered in the receiving slot. It's easy to feel the ends of the slot:
Put the foot base over it. Notice the little image of the car on the base, indicating which base goes in which location.
After doing the same on the other side, drop the crossbar over the hook threads
Finger-tighten wingnut. Leave that little vertical mark pointing toward you, as you see here. That really only matters after the next step, but it's easier to see in this photo.
Tighten with the hex wrench to ~3 N-m of torque. That's about 25 inch-pounds if, like me, you're still living in a backwards country. The wrench is about 4" long, so that's ~6 pounds of force on the end of the wrench. I found one half turn seems to work great. Leave it with the mark facing out.
Lock the lock, snap on the cover, and you're done.
For me, it takes about a minute and a half per crossbar.
To remove, reverse the procedure. Just be careful not to drop the crossbar on the glass! The hardest part, for me, was getting the plastic snap-on cover off. My solution is to pry it off with the key via the slot on the top of the crossbar. Takes almost no force, so I'm not worried about bending the key.
