Roof Tinting Yay or Nay?
lou4gehrig
9
4
Washington
I've definitely read as much as I can on this forum about it. Just curious if anyone saw any issues getting it and if they did what's a recommended tint percentage? One pic I saw on here at 20% looked too dark to me. A local shop that has done 200 MY (and 2 roof tints) has quoted me a fair amount (which I'm fine paying). It's not cheap, so definitely not a matter of cost. My wife will be primary driver and she's had skin cancer type issues so I'm just looking to maximize protection and lower heat when we move to South Carolina next year. The shop uses Xpel systems so XPel Prime XR, Prime HP and Prime CS. Thank for the input.
jeffbco
546
291
Austin, TX
I decided no since I was uncomfortable with the need to drop the headliner for the tint application.
Drivesolo
160
158
Pacific NW
I say nah to roof tint. I got the roof screens (https://www.amazon.com/Sunshade-Ove...ades-Compatible/dp/B07Q9BC8K7/ref=sr_1_3_sspa) and they worked fantastic during the summer. They definitely made it cooler in the car with them than without. It also blocked a lot of the sunlight coming in from the roof so that my window tint looked like the proper shade instead of lighter than it really was. The only drawback is if you're really tall or have really tall people riding in the back they might find their heads touching it.
Reactions: empiredown
Clark_Kent
271
208
Atlanta, GA
I suggest visiting the shop and seeing each shade in person to make an informed decision. Looking at photos online or asking folks for advice is not that helpful as everyone has different VLT tolerances. If you request it most shops will also cut a small piece of film and throw it on your window for you to live with for a couple days to get a feel for what it will look like on your car.
Darmie
1,437
997
Clear Lake TX.
Our MY we bought used. The roof glass was already tinted. Previous owner did not mention taking the headliner off to perform the work though.
Lounanne
125
81
Las Vegas
I have 70% on windshield and roof. I took delivery mid September so I admittedly have not dealt with a full summer out here yet but so far I am happy with it - no visibility issues for me considering the roof is already dyed. I do not use a shade either for the windshield or the roof.
jeffbco
546
291
Austin, TX
I hadn't heard that, but that's definitely good to know. How's the heat then in Austin? Do you use a sunscreen and did you tint the windshield / windows?
I'm not a definite "no" yet to tinting the roof. I don't like the look of the sunscreens. Here's what the guys at Xpel told me:
"For the roof of Teslas, Tesla has actually done a really great job with the coating of it. That coating reduces a lot of heat already. Keep in mind that the glass itself will still get hot and you will feel radiating heat from glass itself. But because the glass gets hot, specifically the roof being so perpendicular to the sun, we do not recommend a dark shade. Dark glass retains heat more, hot glass is more likely to crack. So if you are looking to reduce the heat even more, we would recommend a light shade, maybe 70% in the XR (blocks up to 88% of the heat) or the XR+ (blocks up to 98% of the heat)."
Premiertint
Local Vendor - NorCal
Sep 6, 2018
183
125
El Dorado Hills , CA
The roofs of the Model Y and X have a very good IR built into the glass. Adding a light film isn't going to be very noticeable for the heat blocking. The screens are cheaper and relatively easy to install for shading the car.
used2bsane1
New Member
Oct 3, 2020
2
0
I live in Northern California. I tinted the entire car. Windshield and roof 50%. I hate having to put up a sun shade all the time and I appreciate the extra UV protection on my dash.
ArizonaJon
73
26
Tucson, AZ
When I followed your link it was for an M3, not an MY. Did you use this on a MY?
Srad600Volt
290
184
Southern California
I vote yes. I had my roof tinted and I've had zero issues with it. Looks great and keeps the kiddos nice and cool in the back. Not to mention the added UV protection. I don't believe they dropped the headliner either, seems like that would have taken much longer to accomplish than it did (if they did it was a fantastic job because I cannot tell). I'm not a fan of having to insert/remove screens from the car. If it was permanent and rolled away (or something) I'd be more inclined to go in that direction.
jeffbco
546
291
Austin, TX
Tint with dropped headliner is a 4-5 hour job.
MY-Y
823
871
MD
With a plastic film in the laminated glass, I'm pretty sure it has nearly 100% UV protection already. If you want a darker car, go for it. If you are looking for UV protection or heat reduction, I'd skip it. If windshield tint is legal in your state, a light heat-blocking film there would likely have much greater benefit than adding more tint to the dark roof.
