I now have nearly 6K on my MSP and I am planning to rotate the tires. Have same wheels & tires front & rear.
Here is what I plan to do checklist.
Am I missing anything?
1- Park on level cement and chock wheels
2- Set suspension to high mode
3 - Set MSP in Jack Mode
4 - Put jack pad pucks on front and rear on one side and using 2 jacks, jack up side front and rear
5 - Remove lug covers on both wheels
6 - Remove lug nuts on both wheels
7 - Inspect & clean tires and wheels
8 - Inspect disk brakes
9 - Swap front and rear tires
10 - Snug up lugs
11 - Torque lugs to 129 ft/lbs with my digital 1/2" torque wrench using cross pattern (front and rear)
12 - Replace lug caps
13 - Lower jacks and move chocks then repeat for other side
14 - Turn off Jack Mode
Thoughts?
Normally the SC rotates tires at 12K check up but tires should be rotated every 6K miles according to manufacture (Michelin) if they are the same all around.
M
10 - Snug up lugs
Thoughts?
M
