Msjulie
It is indeed easy to do...unless one has a narrow single car garage with no space to use a jack and has a sloping driveway and lives on a street on a hill.
You got me there!
But I don’t like the idea of asking a shop to work on my car for free. It just seems weird to me.
They should not be so tight that you can hand loosen them.
$125 is outrageousTesla quoted me $125 to have the ranger come to my house and rotate tires... what are people paying at places like Costco or Jiffy Lube, etc.
Yeah, but Tesla recommends 129lb of torque, which is pretty dag on tight
my old car was 80lbs of torque, that's hand loosen
Actually, the 2011-2013 Tundra with steel wheels called for 154 lb. And that isn't the highest: the Porsche Carrera was 407 lbs. I tried to find a better chart, but here is just one of many floating around the interwebs: https://www.jegs.com/images/photos/300/326/326-wheelnuttorquespecs.pdfThat is indeed very high. My Tundra 4WD wheel lug nuts torque spec is 100 ft-lbs. Most torque wrenches are a bit over 100 ft-lbs. Anyone know why it's so high ?
I believe that torque figure for the Porsche is for their center lock wheels... totally different than lug nuts.Actually, the 2011-2013 Tundra with steel wheels called for 154 lb. And that isn't the highest: the Porsche Carrera was 407 lbs. I tried to find a better chart, but here is just one of many floating around the interwebs: https://www.jegs.com/images/photos/300/326/326-wheelnuttorquespecs.pdf
Finished the rotation on my own after a visit to harbor freight... told Tesla to pound sand for $125. 3 ton low profile jack at $108, 21mm deep socket for $4, torque wrench for $5 (special... normally $30), and jack stand for $20. Took about 25 mins total... after reviewing some good online videos.
Ive used the same torque wrench from harbor freights for 15 yrs. It’s been used on my turbo build, BMW and 350z builds so I wouldn’t knock it. I’ve recently used this on my Prius tear down of the top block. I’ve done dozens of engine work. It might not be pro quality but for an amateur mechanic it works. No need to spend more than you need to it.You're a brave man to trust a torque wrench from Harbor Freight.
I did tire rotation at home today.as a person who experience their jack failing on them, never do this without jack stand even when you are not going to be under it. I my self got the rennstands for this purpose with my m3. My trusty floor jack of 9 yrs failed on me a few years ago working on my bmw and that was frightening.
Well there's your problem...I noticed my 3000lb harbor freight floor jack...
I have the JackPoint jack stands for my car and they work great. They have a Tesla-specfic pad for the Model 3. People also like the Rennstands.2. How does it work with jack stands? That is, you jack it up, but you can't put the stand where the jack is. You jack the whole side up?
JackPoint Jackstands, LLC.
The RennStand by Safe Jack
