A working hypothesis is that there is some combination of suspension hardware or assembly procedures which is causing a rough ride. Alternatively, this is all in the heads of the owners. I believe the latter is less likely since as you point out, most people are reasonable and knowledgeable. That's why I think it's important to have some data. Lots of random anecdotal reports don't really give us any good information (the plural of anecdote is not data).The fact that you don't have any complaints is the reason we are hopeful and trying to figure this out. Those of us with complaints are reasonable and knowledgeable.
It would be good to have a recording when you feel the rough ride to compare with a recording when the ride feels OK.I think cab's idea rings true for my brand new s60d (coils 19 Goodyear touring set at 41 psi) if the body panels are any indication of attention to detail during assembly. The trunk, hood and right doors are misaligned greater than 1/4 inch! I hope this is not because of the frame!
I put the accelerometer in the trunk and then the frunk and jumped up and down 20 times on the sill and it felt like something loosened up. The vibration readout shows wide wavelength generally constant 1 to -2.0.
Then I road tested( they are snowpacked) and it was reasonably smooth. I went to a concrete road with joints, accelerated to 40mph and then coasted back down to 20 mph. A harmonic developed and the headrest pounded my head in rythm. The vibration wavelength was very narrow and spike to -2.0 but consistently rebounded to 1.0.
My vehicle has a regen breaking option of standard or low. I switched to low and repeated and I felt like it was smoother but the vibration readout seemed similar with slightly less amplitude.
I switched back to standard and repeated 10 times but could not get the rhythmic headrest beating to come back. The rough ride is very intermittent and hard for me to consistently repeat.
I'm in Carbondale. Its snowing a lot, the SC tech was supposed to come up last Friday from Denver but snowed out.... What is the name of your tech?where are you located in Colorado?
One data point. Last time I had the SC look at the rough ride they said they loosened the entire suspension and retorqued under load. It didn't help. They also performed an alignment.
I'm in Morrison and yes, I use the (one and only) Colorado Service Center on Evans. I was just there on Saturday because of a TPMS/tire issue I've had since the day I took delivery. Wouldn't you know it, I have had my CR-V for 20 years and never had a flat or leak and it looks like I've had a nail in one of my Model S tires since delivery day. Of course it was unrepairable and required a new tire.JPRiver and MorrisonHiker - where are you located in Colorado? Do you use the Tesla - Evans location? I am in Denver. SC might take the problem more seriously if we work are all talking with the same tech(s).
Well, the air does get worn out with all that compressing and decompressing so you probably have "tired air" after a week.Another data point for air rough riders. This is probably getting into the realm of crazy talk but, one thing I've noticed is that, if I go at least a week without the air suspension having to add air (ie, no other passengers or loads or raise to high/very high), the suspension seems to smooth out a bit. If I add air by adding passengers/load or setting high/very high setting, once I get back to standard height with no load, the ride quality sucks again. I wonder if there is a difference in spring rate for air bags filled with fresh air vs week-old air. I think I'll use one of the accelerometer apps to test this theory..
New One data point. Last time I had the SC look at the rough ride they said they loosened the entire suspension and retorqued under load. It didn't help.
Yikes!
This saddens me greatly. I was hoping they could just replace the shocks or something.
[snip]
My plan is to have them drive the car for a week while I'm in Maui and try to figure out ANY way to soften the ride.
If they can't I might sell and buy an inventory model AFTER driving it to work and back.
Weird to sell a car with 500 miles on it but...
It might be useful to look at some of the analysis that VibSensor does. The ISD, RMS vibration and Resonances could give useful information. In addition the Plot provides additional analysis of the Power Spectrum and vibration (filters out high frequency).The graph visually didn't show much difference. But then I downloaded into Excel and I could see the differences. I took the absolute value of the acceleration data points and compared the average,median, and the top 10%. My Tesla numbers were 65-69% higher than the X5, They were significantly higher than the air demo and the other coil as well on the highway. Still need to download some other runs before I publish the numbers for those.
The seats were the same on the coils (stock seats) I think the air was leather. I don't buy for a second that the differences are due to the seats.
