Hello! Those in the know, please chime in! I am working on a couple different projects which require running some cabling from the frunk of the Model X to the cabin. If you could advise me, I would certainly appreciate it as I could not figure out an easy way. I am probably missing something.... Thanks in advance
Also,,,, is there a simple way to get 12 volt power in the frunk. I have pondered "add a fuse" but I am unsure of where to ground. Help?
Ok.... in case it helps anyone else... Found a source of 12 volts, a place to ground, and connected a SAE cable and an inline fuse. IMG_9831 by Sandman1962 posted Jul 2, 2018 at 5:36 AM IMG_9832 by Sandman1962 posted Jul 2, 2018 at 5:36 AM IMG_9833 by Sandman1962 posted Jul 2, 2018 at 5:36 AM IMG_9834 by Sandman1962 posted Jul 2, 2018 at 5:36 AM I still need a method to get a cable into the cabin from the frunk.
There is an old dashcam installation method that runs down the A pillar and jumps the gap into the frunk. Only way I've heard about that doesn't involve drilling through the firewall. Dash Cam | TeslaTap
Hey sandman don’t use that point for power! That feeds your fuse box and is fused upstream. Instead, look at where the connection is on the battery terminal (upstream) and use that point. cheers, PS. Wish I saw this earlier to give you a hand, I’ve done the same thing
The reason I say don’t use it is because, whatever you’re installing, if the device shorts to ground your power to the fuse box will be lost and then you’ll be dead in the water
