Rust
Discussion in 'Model S: Interior & Exterior' started by tmyl21, Sep 30, 2014.
  1. tmyl21
    tmyl21 Member
    Hamilton NJ
    I haven't come across any posts relating to this so I decided to put it out there to see if other owners are experiencing this too.
    Adding I haven't seen any models with this issue anywhere at superchargers, service centers nowhere. It's extremely unsightly and bothersome, well it's rust and it stands out big time maybe because it's back drop is a white MS with silver wheels, but nonetheless an eyesore.
    Here's a couple pics with bad lighting and you can see it, but I assure you it's more visible when your next to the actual MS in light since it is inside the wheel. Attached is the driver's side back and front inside wheel pics...
    Normal and acceptable or not?
    Thanks All
  2. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
    It seems to be normal as I've got it too, as have all my previous cars except my BMW 3 series seems to be free of it. I've been tempted to pull the wheels, clean it off, and try to treat with some sort of rustproofing paint, but haven't gotten that far yet.
    On the other hand, I'd be more worried in your case by the apparent cracks in the wheel rims near the roots of the spokes. Yikes! I have the 19 in wheels and haven't noticed anything like that yet.
  3. tmyl21
    tmyl21 Member
    Hamilton NJ
    Thanks for the post...not cracks but dirt run-off just confirmed by running my finger across the rims
  4. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Rust on the hub of brake discs is quite common. My Mercedes cars have it too. If you are considering paint, then use a high heat paint.
  5. Johan
    Johan Ex got M3 in the divorce, waiting for EU Model Y!
    Drammen, Norway
    In Norway Tesla will fix this for you, if you ask:
    (This is not my wheel but a fellow Norwegian owner - I'm assuming they have just brushed and painted the rusty part with metal paint)
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Yeah, it's pretty normal for brake rotors on any car, in a salty environment especially. Just needs a cosmetic clean-up, per Johan.
  7. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    +1...I can always tell a car is from the east coast...rust on rotors and caliper bolts. Salt on the roads in winter is pretty harsh stuff.
  8. Chipper
    Chipper Active Member
    Chattanooga, TN
    Yes, I agree with the others that it is "Normal" but, in my opinion it is still unacceptable. Like the others, I am not sure what to do about it though. I asked Service and was told that, unfortunately, it IS normal. No solution was given and they did not provide a "fix" for it.
  9. iadbound
    iadbound Member
    No. VA
    We have some excellent resources on the fine points of detailing (i.e., MoeMistry). Might I suggest a PM to him, or maybe he'll respond here.
  10. caddieo
    caddieo Member
    Palm Coast, FL
    I recall reading somewhere that the MS is more prone to rust on the brake rotors since the brakes are not used as much compared to ICE brakes, thanks to its regenerative braking.
  11. tmyl21
    tmyl21 Member
    Hamilton NJ
    @iadbound MoeMistry had chimed in and thanks to all others as well.
    Tesla is going to 'wire brush' them and clean them up per a conversation this morning with the SC. My MS is going in in November for something else and it was stated to me that at that time the SC will clean them up I guess and I'll just hope it comes back looking like the MS rotor hubs/hats in the above photo posted by Johan. Just a shame of an issue for a car in this class with this price tag. Especially when you consider it's revolutionary everything else and aluminum body that won't rust. I just say well after all and all....it's still a car.
  12. Johan
    Drammen, Norway
    This is true, but what's really ugly on the OP picture, and on my car, is the rust on the part closer to the center than the brake disc/rotor, the part which I believe is correctly termed the wheel hub. That part gets the same ammount of rust on it regardless of how much or little the brake is used. Tesla really should have somehow better rust protected the hub.
    For terminology reference:
  13. Skotty
    Skotty 2014 S P85 | 2020 3 P19"
    Kansas City, MO
    Normal for a typical car, but then again, the Model S isn't exactly a typical car. I wouldn't fault them for it, but it would be nice if they tried to rust protect it in the future, especially if the wheel design makes it more noticeable than it would be on the average car. Suggest it to Tesla as a future improvement.
  14. iadbound
    iadbound Member
    No. VA
    My bad. Reading too quickly.
  15. gnychis
    gnychis Member
    Boston, MA
    I've got it and I'm on the West Coast... so I wouldn't isolate it to east coast
  16. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Fairly easy to rectify if you can dismount the wheel and take the time to tape, clean, brush and paint.
  17. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
  18. kevincwelch
    Chicagoland
    Both very good points, although you can remove paint on the rotor itself if there is overspray, etc.
  19. ThortsMD
    ThortsMD Member
    Seattle
    I had a moderately bad case of similar rust in Seattle. Tesla folks looked at it, thought maybe a detail place had sprayed some sealant or other stuff on there...They replaced my rotors...all four. No cost. There was an earlier discussion of this topic if you search...Major Rust on Rotors in a few hours ?
    I cannot say enough about Tesla's service. Any little thing and they jump right on it and make it right. Amazing.
  20. kevincwelch
    Chicagoland
    While I agree that they are great, when I showed it to Tesla service, they basically said it was pretty common and that there was nothing they could do about it...
