I have a modified portable EVSE for my Leaf that can do 16A 240V (instead of the stock 12A), as someone modified the pilot signal generator to send a 16A pilot signal instead of 12A. It was mentioned that if you plug it into 120V and then into the Leaf it will only draw 12A. Apparently the Leaf is like the Roadster in that it ignores the pilot signal and draws at the lowest current level when it detects 120V. So, I think we may be out of luck trying to get 24A out of those trailer park TT-30 plugs. As was said, "Look for the 50amp service" so you get 240V that can do 24A/32A/40A depending on how good of circuit breaker they have behind the NEMA14-50.
(Us early Leaf owners are stuck at 16A max, and can look on with envy as Roadsters draw many times the current.)
