RWD quicker after V9 2018.42.2
Discussion in 'Model 3' started by spurs10, Oct 31, 2018.
  1. spurs10
    spurs10 Member
    Vancouver Canada
    Anyone noticing the car has been more responsive and feels quicker after the update?
    I felt that way but just wanna see if it was just because the shoes I was wearing today.
  2. omgwtfbyobbq
    omgwtfbyobbq Active Member
    Southern California
    I'm not sure if it's any quicker, but it's definitely more responsive.
  3. ord3r
    ord3r Member
    Yeah it feels a lot quicker to me. Quick someone get some Dragy results!
  4. woodisgood
    woodisgood It's walnut, beech
    San Francisco
    Hallelujah we've been uncorked!!!!
    Oh. What's that? Uh-huh. No? Okay, sorry.
  5. Tdriver
    Tdriver Member
    Palm Desert, CA
    Gotta have the numbers or it did not happen......talk is cheap.
  6. ebmcs03
    ebmcs03 Active Member
    So Cal
    Don’t believe it. Tesla wants to keep our RWD slow as a turtle so they can sell more Performance and Dual motor versions.
    • Disagree x 1
  7. Eth3r
    Eth3r Member
    Can you explain the responsiveness of the car, I thought there was really no delay with electric vehicles to begin with.
  8. 75Shappyt
    75Shappyt Member
    Kansas City, Mo.
    I have a 2017 RWD MS75. and the car does feel better, after 42.2
  9. timk225
    timk225 Active Member
    Pittsburgh
    If it doesn't rain, I'm going to the dragstrip this weekend, we'll see.
  10. doehringm93
    doehringm93 Member
    Tampa
    Man I would love if this were true lol
    I'm with ebmcs03 on this one
  11. chronopc
    chronopc Active Member
    I would love to just receive the update. :(
  12. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Tell that to the I-Pace drivers. (The delayed response was Bjorn's biggest complaint about the I-Pace, besides the horrible high-speed efficiency.)
  13. omgwtfbyobbq
    Southern California
    IMO the pedal mappings from before the update were decidedly non-linear. By that I mean negative/positive acceleration versus pedal position was flat/low in the middle of the pedal's range, and was markedly higher near the ends. If I didn't feather it just right at a certain point in the pedal's travel when slowing down the car would slow down a little faster than I wanted it to, and vice versa in terms of acceleration.
    The pedal mappings now are much more consistent insofar as the change in acceleration compared to the change in pedal movement is more predictable/consistent across the pedal's entire movement range. With the last version, it was relatively flat in the middle (large inputs resulted in smaller outputs) and increased sharply at each end (small inputs resulted in large outputs).
    • Informative x 3
  14. MMBTUS
    MMBTUS Member
    Palm Beach County Florida
    Excellent insights.
    The control response you describe is one that RC aircraft pilots have known for years. It’s called “exponential” or expo. It alters the otherwise linear servo power curve to increase or decrease sensitivity at the center of servo travel. We dial in at the transmitter exactly how much expo we want. It is customary to set expo to reduce the response in the middle of the curve to smooth out flights. Doing so makes it feel exactly the same as your sense of the old firmware. More responsive at high and low control settings but less in the middle. By analogy maybe Tesla has dialed out the throttle “expo” and made the power curve more linear in the new firmware. Makes perfect sense. I’m gonna feel for it. Helps to know. Thanks.
    Notice how 42.2 materially improves efficiency?
  15. spurs10
    spurs10 Member
    Vancouver Canada
    After 42.4 update I took a quick drive
    It seems car is not as quick as before? Anyone can confirm?
  16. omgwtfbyobbq
    Southern California
    Thanks! I'm not sure if 42.2 did anything to efficiency. I'm leaning towards yes, but I didn't have any of my routes nailed down enough to feel confident it did. And even if it did, I'm not sure if the improvement is from an actual change to the motor software, just because Tesla dialing out the throttle expo helps drivers better use regen, or both.
  17. VT_EE
    VT_EE Active Member
    Maryland
    LR RWD is no longer for sale so why would they care.
    • Informative x 2
  18. chronopc
    Maybe they want to push the Mid Range. A lot of people on the waiting list still.
  19. omgwtfbyobbq
    Southern California
    This! They went with 1 less charger board in the MR and apparently an IGBT based inverter instead of the SiC MOSFET based one in the LR. If they can get the price of those down right around the time they finish the newer/less expensive SR pack casing/penthouse, I'm hoping they can start offering a SR with the pup for $40k+. Ideally they can go straight to the $35k+ base SR, but I'm not holding my breath.
  20. spurs10
    spurs10 Member
    Vancouver Canada
    We should be glad you are not working for Tesla?
