i just looked at two MS60’s. One had 32k miles and the other 56k miles at buy here pay here lots. Charged to 95% each showed 170 and 165 miles. What’s up with that? Are those batteries abused ? Does Tesla count them as defective?
The Refresh software limited S60 (mid 2016-2017) is not comparable to the older Nosecone S60 (early 2016 and older) since the batteries are not the same. From the 90% rating the OP had mentioned, those are definitely older nosecone S60 models.on the 2017 MS60 I had, got 187 at 90% got the up grade to MS75, 218 at 90%
Certainly. I had been charging between 50-70% SOC daily for over a year, and my 100% had slowly drifted to 154 rated miles. I inquired with my local SC and NA Service who both said my car was fine. They suggested that I charge to 85-90% SOC daily instead of 70%. I started charging to 85% daily (running between 65-85% SOC daily). My 100% SOC gradually rose to 180 rated miles over several months and has since plateaued. My initial range was 205 rated miles.Can you clarify what you mean by at one point. Did you recover some range? If so how?
Is there a screen somewhere that tells you the SoC? The little battery icon shows mileage, the charger setup page allows me to set the SoC for charging... but how to do I display SOC live when I wnat to know?
You may want to go back to rated miles. No one uses ideal miles. I don’t think that’s even an option on Model 3, it was so infrequently used on S and X. Ideal usually vastly underestimates how many miles you use on a trip, unless you stay at 50 or 55 mph. Rated miles is closer, but will underestimate by 20% or so at 70-75 mph.Thanks for the tip about the rated vs ideal miles guys. I flipped it to ideal miles and my wife just drove from Augusta GA to Atlanta GA... 143 miles, and the battery showed 147 fewer miles upon her arrival. I figure those "4" missing miles are the air conditioner running. So my guess-o-meter is right on the money!
Not an owner yet but looking at a 2013 S60 RWD with >100k miles. I can see from the posts above that I can expect anywhere from 150-180 miles with a ~90% charge. I’m in central Indiana where winters will be below freezing and the roads will often have snow on them. Also, unfortunately, I’ll have to keep the car outside.
Given those conditions, what should I expect for winter range?
Thanks
