SAE J1772 Holder in Glove Box?
Discussion in 'Model S: Battery & Charging' started by RiC0MD, May 17, 2015.
  1. RiC0MD
    RiC0MD Member
    MN
    Hi All,
    Just took delivery a few days ago, and have been doing a lot of reading. One thing I keep seeing is references to a cubby inside the glove box that should hold the J1772 adapter. I've checked below the 17" display, and the glove box itself, I don't see anything that this adapter could fit into.
    Could somebody please take a picture of there's so I can make sure I'm not loosing my mind or making a very silly mistake?
    Thanks!!
  2. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    There's a slot at the rear left corner of the glove box that it fits nicely in.
  3. Odenator
    Odenator Member
    Olympia, WA
    Nope, the two little recessed areas in the glove box are now gone in all the new dual motor cars. Our old P85 has them, our new P85D does not. Terrible decision on Tesla's part.
  4. RiC0MD
    RiC0MD Member
    MN
    IMG_0614.JPG Just to confirm then, my left corner should be looking like this (flat), what is that little odd circle on the left wall there? Haven't been turn up any details on that.
    Thanks!
  5. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Recent VINs have lost the little nook in the back corner of the glove box that had been perfect for the J1772 adapter. Some component behind there must have been rerouted.
  6. SBerg
    SBerg Member
    Solvang, CA
    I never knew there was a holder in the glove box. Always keep miy adapter with other adapters in the charging cable bag and keep it in the trunk.
  7. rickgt
    rickgt Enthusiast owner/member
    Carmel
    First the Frunk looses space, now the glove box... oh well, the price of progress
  8. jgs
    jgs Active Member
    Ann Arbor, Michigan
    My 85D has them.
  9. travwill
    travwill Active Member
    Chicago, IL
    Interesting. Seems like it is going to be hit or miss on who has the recess in box right now unless the trend moves more towards no one having it after say mid-May deliveries. It is either that or perhaps a particular option requires the space to be removed; e.g. cold weather or something...
  10. Bonlaw
    Bonlaw Member
    Orange County, Ca
    My 2013 60 had it. Never used it for the adapter. My 70D delivered on 5/9/15, does not.
  11. jbcarioca
    jbcarioca Well-Known Member
    My P85D, built late December 2014, has one.
  12. ddimit
    ddimit Member
    Sacramento, California, United States
    My 85D picked up end of April does not. Im Schedule to have them replace the glove box due to a flaw. Worn spot on the bottom. Will see if I get a cubby or not.
  13. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Well, it's not cold weather -- I've got that. (I don't have premium audio, which I guess might signify). I took delivery in March.
  14. andydoty
    andydoty Member
    Massachusetts
    My P85 had it, my new P85D (picked up end of March) does not.
  15. brianman
    brianman Burrito Founder
    My P85D's glove box has the J1772 indentation. I believe it was built in Nov.
  16. InternetDude
    InternetDude Member
    Yes
    My 04/15 85d does not have the spot and I wish it did.
  17. llavalle
    llavalle Member
    Somewhere around Montreal in Quebec, Canada
    My 85D does not(premium audio + cold weather).
    I got a 60kWh loaner yesterday that has it. No premium audio, no cold weather but it has autopilot hardware. The car was brand new (less than 20miles on the odo). VIN was in the 76xxx range.
  18. Fezzik
    Fezzik P100D, M3LR
    Lincolnshire, IL
    my p85d has it.
  19. Duma
    Duma Member
    My 85D built mid April, 2015, delivered May 6 (regular audio + cold weather) does not have the J1772 cubby in the glove box.
    Based on the posts so far, the only correlation is with date, with cars built before early 2015 having the cubby independent of dual motor, audio package, and cold weather package. No one has reported on whether a recent S85 (built April, 2015 or later) does or does not have the cubby.
    It sure sounds like it is a change affecting all models, although it may have been phased in a little earlier for dual motor builds. Unclear what the technical reason for the change might be since early P85D's still had it, so can't blame it on dual motor (unless it is to reduce noise from the front motor).
  20. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    Uh, there's a comment three up from yours stating an April 85D did not have the cubby...:confused:
