Salvage Model 3 charging problems, how to get it repaired?
Rupy98
5
0
Miami
I acquired a salvage model 3 that unfortunately seems to have some electrical/battery problems. It's indicating that it's unable to charge to 100% and BMS_a064_SW_SOC_IMBALANCE. It's also in reduced power mode.
Any ideas on how and where i can get that repaired (I clearly can't do it)... Someone told me that it's not as straightforward as getting a new battery and putting it in as the car would need firmware and I would therefore need someone who can hack the model 3.
I did consider taking it to tesla, have the inspection done for the ~$500, and look to get a quote from them to fix, but the car can currently supercharge and doing the inspection will disable that is my understanding.
Yes, I understand these are all the challenges with having a salvage, told myself that and kicked myself a couple times already... so what I would love from the community instead are ideas on what next... thanks much
MRGEDU
95
56
DELMARVA
I know this is not directly helpful, but if you want a Model 3 then see if Tesla will take it on a trade, it may be your best way to get the most money for it. Supercharging is useless if the car doesn’t work correctly.
Reactions: MXWing
bart_dood
131
65
Martinez, CA
Why don't you use the OBD and pull the pack voltages and see if one of the sub-packs is bad? shouldn't be too expensive to swap a sub-module out to repair it?
MP3Mike
14,978
31,851
Oregon
The Model 3 doesn't have an OBD port. And there are only 4 modules... So looking at ~$4k at current market prices for a module. (Assuming they would sell the correct single module since they aren't all the same in the Model 3 like they are in the S&X.)
Rupy98
5
0
Miami
I didn't know they would even consider a trade... seems weird that they would, but i'll explore.
Rupy98
5
0
Miami
But assuming that it is the correct module that is out of balance, would I then need the software access as indicated before?
MXWing
7,270
17,738
This is CLUTCH advice.
Tesla is so disorganized they can't even cut their way out of a wet paper bag with a ginzu knife.
@Rupy98
I would say the probability is pretty high you get more on the trade in than what you bought the car for.
Reactions: smatthew
