San Antonio Tesla Owners - Questions About Install
Discussion in 'Texas' started by Bardlebee, Dec 22, 2013.
Tags:
  1. Bardlebee
    Bardlebee Member
    San Antonio, TX
    Hello San Antonio people.
    I am going to be putting down my reservation in a few months. But I wanted to know two things that are local to San Antonio.
    1) Who did your install for your charge port at home? I would like to install a NEMA 14-50 unless people here think a 14-30 is more then enough. Can anyone recommend a person/company to install? I am concerned with crappy work and fires starting in my house due to bad electric work.
    2) I am looking at doing the Xpel Ultimate clear coat. What location did you do yours in town if you did this? Does the Xpel Ultimate protect from rock debris on the highway?
    Thanks for the help.
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Check out Yelp for a electrician with good reviews or a similar site. Any electrician can install this and go for a NEMA 14-50 even if you rarely need 40A.
    Not sure who does XPEL in San Antonio but it does help protect against rock chips as does any paint protection film.
  3. Bardlebee
    Bardlebee Member
    San Antonio, TX
    As silly as it sounds, the recent news of shotty electrical work burning down houses has me on edge. But I will give Yelp a try. I should be able to trust the electrician in their profession, but you never know.
  4. bareyb
    bareyb Active Member
    Silicon Valley, CA
    Don't be so sure. I got a direct recommendation for an electrician in my area from someone on this very site. They screwed it up in every way possible. You HAVE to be your own advocate and make sure they use the right wire (6-3), the right Breaker (50 Amp) and put the plug in right side up (Ground on Top). Believe it or not, they managed to do every one of those things wrong on my install. To their credit, they did fix everything but it was still pretty scary that they'd have left it like that if I didn't know any better…. :(
  5. Bardlebee
    Bardlebee Member
    San Antonio, TX
    How did you find out all those things were wrong? I am a networking engineer, not a electrician!
    Was it self study? Something I could look up myself and research? Its good to hear that they fixed it and also good to hear that recommendations aren't always the best. I suppose I might take the Yelp direction on this and study up on EXACTLY how this should work. I have some time waiting on the car anyway :)
  6. bareyb
    Silicon Valley, CA
    #6 bareyb, Dec 22, 2013
    Ironically, it was all in the instruction sheet that Tesla provides for the electrician. Which I gave to him. He scoffed at it and said he'd "done a ton of them" and didn't need it. :rolleyes: Considering the fire they had yesterday from a bad electrical install of a NEMA 14-50, it's more important than ever to be your own advocate and double check the work for yourself. ;)
  7. Bardlebee
    Bardlebee Member
    San Antonio, TX
    Interesting. It is good that you were astute enough to keep your eye on that. This is definitely one area that concerns me. I am going to start taking quotes in the next few weeks (Christmas will likely not get me many quotes this week) and see what comes up. I have heard that it depends on a lot of factors. But the install could be anywhere between 200 to 2k dollars so here is hoping my install is straightforward :)
    I am going to do it before I order the car as a testament to my dedication and to keep my mind busy while I wait.
    I am going to see if I can get a quote from an Xpel dealer in town and report back here on the quote I get. I am leaning towards doing the whole car, I know it will be a few grand but I think it may be worth it.
  8. bareyb
    Silicon Valley, CA
    It usually depends on the distance from your breaker box to the place where you want to install the Outlet. I paid $900.00 for mine but it was across the room from the panel and they had to fish the wire on both ends. I put mine up near the ceiling to take up some of the slack in the cable and now I just hang it on the hook and kick the cord under the cabinets. Makes it really quick to plug in and out.
  9. Bardlebee
    Bardlebee Member
    San Antonio, TX
    I won't be doing the HPWC, so I think I will be good with the adapter that Tesla gives me for slack. Here is hoping! :)
  10. bareyb
    Silicon Valley, CA
    #10 bareyb, Dec 22, 2013
    As for the Xpel? I did it on my last car but I don't think I'd ever do it again. I know a lot of folks swear by it, but for me it didn't turn out to really gain me much. It's still got pits in it and I never really liked the way the light reflected off of it compared to the actual paint. You can wax over it, but it doesn't gloss up the same way real paint does. In the end, it's still a sheet of plastic over the paint on your car and it looks like it. You may want to see someone with it installed in person before you put it on your whole car. That's a pretty big commitment. You can have the whole front of your car repainted for about $1200.00 which is less than you'll pay for a full application of Xpel. Something to think about. I see a lot of guys going for it, and I know a lot of people really like it, but it's definitely not for everyone. Another option is a Nano Coating which reportedly toughens up the clear coat, but I'm a little skeptical about that too… I just use a good Sealant (Zaino or Jetseal) followed by a couple of coats of Canuba based Wax (Butter Wet Wax). It may not repel rock chips as well as plastic, but it looks better. ;)
    - - - Updated - - -
    Just to clarify, that's not a HPWC in my photo. That's the standard (free) UMC that came with the car. Even with it mounted up high I still have plenty of slack to make it to my car without having to coil up a lot of excess every morning. I just hang it in the Cradle and walk away. I used a curtain rod hook I found in a junk drawer to mount it on. The Cradle can be purchased on Teslas website for $25.00.
  11. Cattledog
    Cattledog Active Member
    San Antonio, TX
    Bardlebee - We used Vollmer electric, 824-6313, ask for Brad. Tell him the Papays referred himto you. I'd do the 14-50 so you have options to charge at the max rate (about 30 miles/hour) or dial down as you'd like. They installed 2 14-50s for us anticipating our Model X, now to be used when our second Model S gets here in a couple weeks. $800 for materials and labor, not a long run, but drilled though garage wall to get from breaker box on the outside to outlets on inside. Good luck.
  12. Doug Gallarda
    Doug Gallarda P03915
    Austin, TX
    We used Green Star Solutions. They have offices in San Antonio and Austin.
    Green Star Solutions | Solar Electric and Solar Thermal Green Energy Solutions
    Austin Energy has them on their approved vendor list. We worked with Gary Bynum who did great work. He also helped us qualify for a 50% rebate on the cost of the NEMA 14-50 install through our power company.
    We have an excellent owners club you need to join once you take delivery:
    [email protected]
    Best of luck!
