San Diego electricians to install Nema 14-50
Discussion in 'Model S' started by Eye-O-Matic, Nov 29, 2016.
Tags:
  1. Eye-O-Matic
    Eye-O-Matic New Member
    San Diego
    I just got 2 bids to install a simple 14-50 240 and a std household outlet next to it. It is not more than 20 feet from my box to the location near my car. Two bids, one from Premo electric and the other from Green Electric. Both came in around $1,800-$2,000. This is ridiculous. Please, can someone from San Diego recommend an electrician that is not ripping people off. It is exactly 19ft from the breaker box to where I need the new outlet. This job should not be more than $300. $500 max.
    Thanks in advance
  2. msnow
    msnow Active Member
    SoCal
    Mine cost $600 for a 40 foot run including the permit but it was just for one 14-50 outlet. I used one of the "Tesla recommended/certified" electricians from their site. If yours is also a Tesla installer you should email Tesla and let them know if you think it is too high.
  3. WARP 10
    WARP 10 Member
    San Diego
    I used Premo and they charged around $500 for just a 14-50, part of which was a new 50amp breaker. Outlet is right next to the box. I've heard longer conduit runs can get expensive, but not that much.
  4. msnow
    msnow Active Member
    SoCal
    Not only that, he had two separate outlines and two runs because he wants the regular household outlet there too.
  5. demundus
    demundus Active Member
    Oceanside, CA
    I paid 1500 for a 70 foot run and some trenching i couldnt do myself. Roper Electric did mine although he messed up my line rating, i can only charge at 32a instead of 40. Oh well.
  6. bradhs
    bradhs Member
    San Diego, CA
    I did it myself with the help of a neighbor for $250.
  7. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ In loving memory of Version 8
    Portland, Oregon
    Just bought all the parts for a 40' run for about $100. Should take less than two hours for the install. It's too easy of a job to not do it myself.
  8. bradhs
    bradhs Member
    San Diego, CA
    40' run for $100?? I spent double that on parts and only ran half the distance. I used 1.25" conduit, 2ga wire for the load and 4ga for ground. Not sure what the new Tesla HPWC support but I went with larger ga cable to keep the heat down. (The posts in the old HPWC supports that size with no issue, not sure about the new HPWC.)
  9. pchengMX
    pchengMX Member
    San Diego
    Premo Electric quoted me a similar price too and that was only for a NEMA 14-50. I got other quotes from electricians that were no more than 400. But then I asked them about the permits and they say they never heard of one needed for a NEMA 14-50 installations they have done....? I too is in need of a good electrician...
  10. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    If you drive less than 120 miles per day this is a great solution: DIY Tesla 240V Charging | Quick220 Review
    I spent 3 thousand with installation and permitting (took weeks) for the install of my HPWC. If I had know about quick 220 earlier, I would have taken that route. I am in Irvine, CA
  11. pchengMX
    pchengMX Member
    San Diego
    i just saw that and was wondering how that would be so I may have to look into that.
  12. K-MTG
    Irvine, CA
    What is your daily commute?
  13. spentan
    spentan Active Member
    SoCal
    I used Johnnie West Electric
    (858) 270-5564
    18 years in business
    1633 Diamond St #28
    San Diego, CA 92109
    and Calafata Construction and Electric (http://calafata.com/) for Charging Installations with my Chauffeurs in San Diego
  14. pchengMX
    pchengMX Member
    San Diego
    i work only 3 days a week but my commute is about 65miles round trip.
  15. RandyS
    RandyS Fan of Elon
    San Diego
    Several Tesla owners in San Diego have used "Ms. Sparky Electric" to install their charging circuits and had a good experience (and a reasonable price quote). Mary is the owner and can be reached at 760-942-7345. Tell her Randy from the local Tesla Facebook group sent you...And if you want to meet other local owners, you're welcome to join our Facebook group (San Diego Tesla Owners)...
  16. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    Why not run the wires yourself and just pay the electrician to connect to the breaker panel? It seems most of the cost is in running the wire and, while that's not always easy, it can save you a lot of money doing that part yourself. Connecting to the panel is very easy, but I understand many are not comfortable doing it. Just make sure you get the proper gauge wire.
  17. K-MTG
    Irvine, CA
    If you can find someone under the $500 range for the 240V outlet go for it, or else the quick220 would also work for you which is $200.
  18. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    That doesn't include the permit. I wasn't going to get one. I probably should though, for liability reasons. Maybe I can apply for the permit online. It was more about the hassle than than avoiding permit fees.
    $85 40' 6-3 NM-B
    $15 2-pole 50 amp breaker
    $8 14-50 outlet
    $5 2 gang cut in box
    $3. Cover plate
    $3. Bag of 10 wholly tie wraps.
    So about $120.
  19. pchengMX
    pchengMX Member
    San Diego
    Thanks so much I will keep that in mind!
  20. pchengMX
    pchengMX Member
    San Diego
    She does the permit and everything? I will try to contact her. I am actually on the San Diego group on Facebook. Thanks again I appreciate it.
