San Diego to Yuma to Phoenix - doable?
Discussion in 'California' started by brianstorms, Feb 22, 2014.
Tags:
  1. brianstorms
    brianstorms Member
    #1 brianstorms, Feb 22, 2014
  2. ggr
    ggr Roadster R80 537, SigS P85 29, M3P 80k
    San Diego, CA
    I haven't done it, but I wouldn't hesitate to try. The only real worry would be if there's a headwind out in the desert, so I (being a pilot) would check the weather at Imperial or Calexico airports; the winds out there can be very strong, which is why it's filling up with turbines and solar panels. Just don't succumb to the temptation to keep up with the traffic; 80-85 mph is normal despite the local predators, and that would kill your range. Set the cruise control to 70, then when some sort of SUV crawls past you, slot in behind him, not too close, until he starts trying to figure out what you're doing... then rinse and repeat. No problem.
  3. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    This trip seems like it's halfway between 'no-brainer' and 'doable...barely' in an 85. Just keep your speeds lower at the start of each leg until it becomes clear you'll make it with a nice cushion. 'Start slow; end fast' should be every EV road-tripper's mantra.
  4. Tyl
    Tyl Member
    Phoenix East Valley
    Yuma AZ to San Diego CA and San Diego CA to Yuma AZ are both very doable in an 85kWh. You'll arrive at both locations with about 30 miles remaining if your were fully charged up when you left.....and stayed near the speed limit both ways. I've done it several times. My starting/ending point in San Diego CA was the Navy Base 32nd street San Diego CA.
  5. liuping
    liuping Active Member
    San Diego
    I did Del mar to Yuma this morning. It was no problem. We had a nice breakfast at the Copper Miner Kitchen restaurant (a very short walk from the superchargers) and had 258 miles ready when we walked back to the car.
    Yuma to Tucson was a bit harder partly because I could not drive 65. :) We ended up stopping at the Bowlin travel center for 70amp charge. (Yeah dual chargers). It will be cake once Gila Bend goes live...
  6. brianstorms
    brianstorms Member
    Great, thanks for the info. Hmm, I thought Gila Bend was live?
  7. ZBB
    ZBB Emperor
    Scottsdale
    Nope... It's nearly complete, but not powered on. Similar to Buckeye...
    if your trip is in April, both should be on by then...
