Sandy Munro talks about the teardown of the Model 3
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
Again, very politely.
That is real world experience that I have repeated many times due to track conditions. It is reality in a race car. And no weight is being changed. The car weighs what it weighs. The transfer of weight to the rears occurs during launch and all vehicles (including AWD and the Model 3) will see more load applied to the rears and less on the fronts during a hard launch. As the car accelerates down the track the load on the rears is reduced. You might not want "weight shifting" but it is going to occur as sure as the sun will rise.
This isn't "purposely loading" at all. It's just how the chassis reacts to a hard launch. By stripping the interior of the Talon and replacing the glass we lightened the car substantially and enjoyed lower ET's as a result.
My Nova would pull the fronts off the ground at will. Of course a set of bars will prevent catastrophe but the operator is key to getting it hooked up. The Talon would hook up and go. The fronts would unload as it rises but some camber can add to the available traction.
EV's like the Model 3 are absurdly easy to launch. Just mash the wheel and hang on. I imagine more than a few will make their way to the local tracks.
I believe "very few" people are going to take their Model 3's to the track. This is why I'm wondering why we are talking about the track for such a long time.
The Model 3 is not a track car. - Even though it can do well on one.
I've been to the track with mine - only because I received a free pass. I wouldn't pay track fees - as I would just watch other people on youtube on the track.
ricohman
470
316
Saskatchewan
I thought we had moved on.
In any case, have you made a pass or two in your car? I am interested in the times.
mongo
12,865
37,837
Michigan
Appreciate the politeness. I was not attempting to contradict any of that with my recent post.
Weight shifting is real, contact patches are real, tire loading to traction is a less than 1 ratio is real.
You had mentioned feathering the throttle due to loss of weight shift, am I wrong in thinking that a dual motor EV would not have the same issue due to the front wheels gaining the weight the rears no longer have? Along with the improved traction control.
JeffC
209
82
Silicon Valley
The problem with this statement is that nobody knows whether the tradeoff is slight, or massive. Nobody knows whether its a few grams, kilograms, or hundreds of kilograms of potential weight savings.
Our cars are 1st generations (maybe 1.5 if you want to count RWD as 1.0). Do you really think there's no opportunity for better optimization? I can't think of any 1st generation things that didn't get better with subsequent iterations.
I agree it's a tradeoff, and I am also glad my car is safer than less. But a Model 3 that can perform just as well on crash safety, with a slightly less overbuilt frame can benefit from improved range and handling from less mass. Or if you want to keep weight equal, you can build in a bigger battery pack which would still improve the car all around.
All this talk about Munro and his qualifications only distracts from the above. I've only watched the most recent Munro/Autoline video, and I thought he was very impressed with Tesla (and the Model 3) as a whole rather than not so his criticism of the frame didn't seem to me particularly out of line.
I would propose that the car is not overbuilt, and in fact is very well designed. It would be nice if a few kilograms could be saved, but all modern car makers do extensive weight reduction, including Tesla. They reduced weight to the point where it met their design goals.
One of Tesla's top design goals was safety. Another was efficiency/range. They were and are painfully aware of weight savings and likely spent much effort on it. I would say they met their key goals very well with Model 3.
None of a car's sheet metal parts would be economically changed since doing so would mean producing new stamping dies and tuning their fit with the other stamped parts together. All modern cars are extensively designed and tested in computers and part of the reason for the excellent crash performance of Model 3 is the excellent software used to design it. The results are then tested and tuned before going into production.
(In case anyone isn't aware, stamped steel parts in particular spring back when released from the stamping dies. They don't come out an exact match for the dies. And the tuning of the resulting parts is part science and part art. Software has gotten much better at predicting the behavior of the metal that comes out of the stamping dies, but usually some fine tuning is still needed. As with many things, it's actually the quality of the software and physical modelling contained in it, that is a key determinant. Same is true of internal unit body (chassis) panels and exterior panels.)
Sandy's responses have changed over time. He needs to be slightly political in order to sell his products and keep his customers happy. All of the (recent) praise he has for Tesla is in fairly uncontroversial and obvious areas such as (both electronic and mechanical) module integration, wiring, traction motor, and electronics quality. Any of the car other makers could also see that for themselves very easily.
(In case anyone is unaware, all car makers benchmark their competitors cars by disassembling and reverse engineering them, as Munro does also as an external third party. All of the car makers also do that internally with any new major competitive car. However their internal reports stay internal since the information obtained is competitive information. A reason to have third parties like Munro is for car makers to get an external "second opinion", or for non-car makers like investment banks to understand the parts costs and profits better. BMW, VW (Audi/Porsche/etc), Mercedes, etc., have already torn apart all Tesla models and come to their own judgements about cost, design quality, build quality, profitability, etc., independent of Munro or anyone else. It's totally normal for a GM, Toyota, Nissan, etc. to tear apart every weld on every competitive car to see how they're build. Same with engines, electronics, etc.)
While Munro has a lot of experience, the idea that they are smarter than Tesla may be wrong. That does not mean Tesla is perfect or could never improve, but it's pretty clear they've done a very good job designing Model 3.
I'm not trying to bash Munro or praise Tesla, but I believe Munro's conclusions about the Model 3 unit body are wrong and that Tesla designed it intentionally and purposefully to meet their safety and efficiency goals. It is a matter of fact, not opinion, that the resulting crash performance of Model 3 is the best NHTSA has tested. That happened due to the design of the car.
JeffC
209
82
Silicon Valley
One way to improve the discussion would be clearer language. As the original poster mentioned weight doesn't shift. Load transfers. Weight does not. (Weight isn't really the right term either; technically it's mass subject to gravity.) Use the team load and not weight when referring to load.
Regarding the question of load transfer, each wheel will have an amount of force it can generate dependent on load. The greater the load, for a given tire type, contact patch, surface, etc., the more force it can generate. If you could unload the front wheels enough to have very low load, like on a very powerful RWD drag racer, then the front's can't contribute much accelerative force and thrust should be applied at the rear wheels. However a heavy AWD car will have enough load at the front wheels that the front motor can contribute signficantly to forward thrust, up to some limit.
Some of the load transfer off the front and onto the rear can be mitigated by anti-dive and anti-squat suspension geometries, but they're an aid in the margins and don't overcome ultimate physics of load transfer.
apsen
189
111
somewhere
I didn't misrepresent anything. Here is the video where he admits he was wrong about Model 3 not being profitable.
Go to 2:53 (where he admits he was wrong and it can be built profitably after all). If you want the original video he references here (where he said he didn't think it could be built profitably) you'll have to do your own legwork.
But I'm not sure why anyone would even argue he never said that in the first place. Only if you haven't been following him. And I wish I hadn't because he's as wishy-washy as a top-loading washing machine. He's been wrong more often than a $TSLA short-seller. And that's saying a lot!
That one I'm aware of. I'm not aware of any video where he says it is not profitable.
I'll grant you that you were right about him changing the tune because Cleantechnica quotes him so but I have rewatched the video referenced in that article and still can't find him saying that phrase. I guess I could have missed it because it is tedious to watch the same thing again so I may have spaced out during relevant bit plus there are couple of times when I just can't hear what he says but maybe a native speaker would be able to make it out... Or maybe it is in some other video... In any case I would appreciate if anyone could tell me where I could see it.
mongo
12,865
37,837
Michigan
The one time I use weight transfer instead of force to align with the quoted post...
An AWD would like to stay 50/50, but can't under all accel/ deccel conditions. If the tires are in the more linear portion of the traction load curve, the load shift would have a smallish impact on overall traction.
ricohman
470
316
Saskatchewan
The Model 3 should require no additional input as it has traction control. Just mash the pedal. The chassis will react in the same way as any other AWD. I doubt the car would have the same trouble as the Nova at higher speeds as it simply doesn't have enough power to break the tires loose even if it didn't have traction control.
In a full throttle launch on a Model 3 the rears will load and the fronts will lighten. And the traction control should reduce power to the fronts and increase it to the rears as there will be more traction available. As least this is how I assume it will work as the motors are independent of each other. This and the instant torque of EV's is why they are going to become popular. The eCOPO will be here very soon.
I worry about inner shafts and CV's though. It's only a matter of time and launches until things get very expensive. And the spline count is what it is. But all IFS/IRS cars are the same in that regard.
apsen
189
111
somewhere
To be clear, are you saying that you want the car to perform worse in crashes? Because that's what you're implying.
No that is not what I'm implying. I'm trying to say that using crash tests to dis/prove Munro's statement is silly. It could easily be false or true irrelevant of the crash results. Crash results are exactly that - estimates of the crash worthiness. It could be used to make estimated guesses about certain other areas but is not enough to dis/prove them.
Yes, there is a tradeoff in cost/weight versus safety. I think Telsa made the right tradeoff if it's biased slightly towards safety. If the car is a few kilograms heavier but saves even one life or prevents one major injury, it's probably worth it.
That is not the only possible trade off. I'll repeat this again: the way that Tesla have built Model 3 may have been a completely conscious decision on their part but other news suggest that there's at least some truths to the Munro's words. And I'm not talking purely about crash tests.
But if you want to argue about crash tests there's no way to disprove Munro's opinion that you could save weight/cost without compromising crash test results without building a car that would incorporate his suggestions and testing it. Just as there's no way to prove your statement about Model 3 performing above what is currently tested without doing more stringent tests.
If you are right and the car is indeed has better performance in the crash then I'm glad I have that but I'm not convinced. On the other hand if Munro is right and Tesla changes the design I still cannot benefit from it except potentially in some rather distant future barring sudden big changes in my life.
ricohman
470
316
Saskatchewan
I read years ago that the ideal weight distribution is slightly to the rear. Adds traction for acceleration and balances the car for braking. Road racing designs. I imagine this still mostly holds true as far as purpose built race cars go.
But lets get back to fit and finish. How is the assembly on the cars that all of you are driving?
Is it 90's Kia or like a new Honda?
paranoidroid
182
173
San Francisco
I have two BMWs, not as good as those but not bad at all and very much passes my standards. Closer to new Honda on my example and this includes paint quality as well.
You def. need to drive a Performance Model 3 with your car experience, you'll love it.
Reactions: ricohman
mongo
12,865
37,837
Michigan
It's literally a 2002 Sierra with rusted out rockers...
And don't get me started on weight distribution.
JeffC
209
82
Silicon Valley
I will bet you the price of a new Model 3 that there will be no major changes to the Model 3 unit body chassis within the next 5 years.
voip-ninja
Give me some sugar baby
Mar 15, 2012
4,121
4,691
Colorado
That leaves you lots of wiggle room since the definition of "major" is rather nebulous.
If they reworked the rear trunk assembly so it wasn't a bunch of welded sub-structures would that classify as major for you? It would for me and we could see that when they start building in China next year.
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
It is definitely not as good as a new Honda but not as bad as a 90's KIA. Munro criticism there was too harsh but I also don't know how bad his early production sample was.
My 1st BMW F30 had a few panel alignment issues, all of them more or less did the 1st year BMW was into production with that model. The paint however was perfect. The car did have a rattle that BMW never sorted out. In that comparison my Tesla is actually better as so far they've been able to fix the things making noise in the car. I haven't asked Tesla to fix the minor alignment problems as I'm more concerned they will do something to make the car worse in the process.
Weak spots to me;
  • The door seals are really flimsy and don't seem to fit great. I see long term owners having to deal with this at some point.
  • My driver's side door to rear door alignment is off a bit... I've seen multiple copies parked that have the same 'defect'.
  • Hood slightly sunken on one side.
  • Some fabric on the forward dash is bunched up a bit and creased. I was able to smooth it a bit and I'm not obsessing about it.
And that's about it. I was worried I was going to have tons of issues with fit and finish but really haven't. That said, if you are the type of person who buys and returns five iPhones trying to find a "perfect" one because you obsess over details only seen under magnification then this is not the car for you.
Reactions: JeffC
ricohman
470
316
Saskatchewan
Weak spots to me;
I'm not the iphone guy but I am an automotive enthusiast. Although I am a mechanic I also paint and do bodywork and frame work. As a painter I can be very picky and as a body man I am also picky. I agree with letting some panel issues slide as no doubt they can be made much worse. I saw a video of some guys raising the striker plate on a Model 3 to "fix" a door alignment issue. That is a good example of making something worse.
Going to order red. I can't figure out how Ford can paint my massive F450 in white platinum tricoat for $550 and Tesla charges $3300 for red?
I know candy red is expensive as I have used it before but we are getting hosed here.
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
Tesla is charging through the roof for options but I wasn't aware they were charging $3300 for red paint. Are you sure that's for just paint and not for paint and a white interior?
I would anticipate needing to polish the car when you get it, or better yet if you find things at delivery that can be finished by paint correction then twist Tesla's arm and make them eat the cost of paint correction.
Mine was pretty good when new, they must have some new detail guys at my local SC. I still ended up polishing it and then did a ceramic coat on it.
Otherwise I think you're really going to like it. Even with the hit to range in the cold weather we get six months out of the year I'm really happy with this car and driving something else now seems mundane.
