I am dealing with a significant rule change in Santa Clara County Fire jurisdiction, which is effecting our ability to get permits for Powerwall installations. SCC has retroactively applied new rules to our existing permits and is rejecting our other new permits based on their rules. These new rules were supposed to come into play in July 2021 with the interim code update.
They are enforcing these rules immediately and retroactively to permits from last year. Anything for more than 1 Powerwall needs to comply, and have even more strict rules for more than 5 units.
These are the really onerous requirements:
1. No Powerwalls closer than 3' to each other, so stacking kits are not allowed.
2. Limiting the Powerwall locations, and quantities in those locations.
3. If the PW are in an attached garage, all interior of the garage must have sheetrock.
4. Attached garages must have Listed heat detectors, which trigger an alert in the rest of the alarms.
The heat detector requirement has me looking at codes and products I am not used to worrying about. What i am hoping for is a product that we could retrofit in a garage, and/or home, which accomplishes this without new wiring or with as little as possible new wiring. So far all the wireless heat detectors I have found are designed for interfacing with a main control panel, which may not exist in an older home.
For instance this is my preferred wireless Smoke/CO detector. https://www.amazon.com/First-Alert-...&sr=8-7&swrs=C4E1F7315C16AEAE46DFB47BBDE7FD72
Unfortunately it doesn't come in a heat detector version. If it did that would be perfect.
I looked into NEST as well, but it has no heat detector option.
