SC recommends paint job
Discussion in 'Model X: Interior & Exterior' started by steilkurve, Jun 5, 2018.
  1. steilkurve
    steilkurve Member
    Montreal, Canada
    So I was doing the walk around with the tech when dropping off my X for its annual inspection. I didn’t ask but he mentioned they could send the car to the body shop to fix the paint damaged from the FWD rubbing against the body. Mentioned they repaint and then apply a 3M tape for safety. Anybody done it and is it worth? Did it keep the problem from reappearing? Thanks.
  2. r0xx0r
    r0xx0r Member
    #2 r0xx0r, Jun 5, 2018
    No, it isn’t. The rubbing is still happening, but the tape saved it all.
    They did upgrade my pinch sensors to the newer version. The bodyshop did some aluminum works on the door. Changed the pinch points, it is shorter than the original. Also, they aren’t good at putting panels back. I got more squeaky sounds on the doors after serviced. IMG_2870.jpg
  3. steilkurve
    steilkurve Member
    Montreal, Canada
    Thanks. Would you do it all over again despite the new creaks? Just evaluating if it’s worth it.
  4. r0xx0r
    r0xx0r Member
    Yes, I would. We have to deal with squeaky sounds because of Tesla’s fancy snap-in components. I will let them check it in my next appointment.
  5. Padelford
    Padelford Supporting Member
    Seattle
    There are new FWD parts “available” that supposedly cure the FWD door rub problem. I’ve been waiting for all of them to show up at my SC for a month now.
