Hi, Finally we have an official thread in this forum! Ask questions, share your findings, and make this thread awesome. I will try to answer all questions, and take note of any feature requests. Google Play links: Scan My Tesla Scan My Tesla DEMO (this is just a UI demo, playing back a recorded log) Documentation: scan my tesla Background: There was so much cool canbus stuff floating around the internet, especially on this forum, but it was really just floating around. I decided to create an app that could decode and display all those known canbus packets, and a framework that would quickly allow me to add new packets when they become available. I credit all the reverse engineering work to those who deserve it: Most CANBUS packets decoded by Jason Hughes (skie.net) Battery cell info decoded by Jack Rickard (evtv.me) DC/AC Charge counters publicized by "DB 2" HVAC controls by Marc Olivier Chouinard (teslalog.com) Trip recording system idea by Marc Olivier Chouinard (teslalog.com) Efficiency calculations suggested by WarpedOne I have since added a lot of my own, mostly combining already known packets into more interesting ones. There is also a simple trip computer, a bit like Tesla's in-built one, but you can have unlimited numbers of them, and it shows you regenerated energy and %, AC and DC charged energy. For those interested, I am working on a canbus reverse engineering suite, inspired by comma.ai Cabana, called CanbusAnalyzer: amund7/CANBUS-Analyzer The app source code is also in github: amund7/ScanMyTesla
Thank you for building this. I notice you have hardware requirements listed in the documentation. What wiring configurations do you support? Specifically do you support the ten wire, four CANBus setup? Do you plan to support the Model 3 if hardware isolating the CANBus becomes available? For those new to hardware required here is some detail: Diagnostic Port Index Happy to analyze any CSV exports for your users, especially if appropriate for understanding performance drivers like power and torque limitations, back EMF and thermal tolerances.
AFAIK, ELM327 and STN1110 command sets does not support multiple canbuses simultaneosly. I have a comma.ai Panda for testing, but that has a so incomplete ELM327 implementation that it is useless for Tesla. It could probably be a good platform for multi-bus reading, but it would require moving to USB or WIFI for the connections, removing all the ELM stuff, i.e. a complete rewrite of the app. And the gains are, well, debatable. Do you really need an app to log for 2 hours that your door is closed... stuff like that I think is a lot less useful than the CAN3/powertrain we are currently hooked into. And there is still so much unknown data on CAN3, I would prefer to keep exploring that bus first. Just realizing this was maybe not what you asked, the real answer is 'I don't know'. Will can3 line up with the 'regular' wiring in the 10 wire config? If yes, then maybe, except if the obd2 adapter's auto detect features will be confused with the data from the other buses. I am very eager to support Model 3, I saw you have a little bit of info on it in your thread, seems like OBD2 adapters will not work anymore? I suppose in any case, it will have to be a completely different app, as I am guessing the CAN packet ids will not be shared with S and X.
It was originally planned as a cross-platform project, but turned out not to be so easy (for me, I am Apple illiterate). Basically I would need to team up with a IOS developer, who would have to re-write the UI and bluetooth code for IOS, while basing the core functionalities on a shared code base. Anyone interested let me know. There will be moneys to be had!
Glad to have a thread for SMT which is my favorite app. One thing I'd like to do is to make recording while supercharging or on special trips and graph it later by Excel. Do you think the 'lags' (such as the 'Cell temp min' circled above) is due to the slow speed of my ELM327? Or simply the canbus just lazy in sending this information? Or combined? Also, can two versions of SMT (such as 1.1.0 and 1.4.3) be installed on one Android phone? If not, I may have to use two phones (but that's Ok for me).
Thank you for your kind words! About the jagged lines of max and min values, it happens because all of the battery cell temperatures have not been updated in a while. Probably this is because your ELM device gets flooded with too many packets too fast, and it randomly misses some of them. There are 2 solutions - log fewer different packets - or get a faster adapter, ODBLink LX is now the best adapter for the money I believe. As you are on to, it's a combination of rare/slow packets for the battery cell readings, and too much fast packets causing the adapter to miss some. Scan My Tesla helps you clean up, if you double tap a gauge or reading, it will select other readings within the same CAN packet ID. Meaning, there is no use deleting Battery Voltage if you keep Battery Power, since they both come from the same CAN packet, and the app would still have to keep that packet coming in. If you delete both, the app can change the hardware filters of the adapter, and lock out more traffic. With ELM327 devices the filters are bit based, so the filters have a very limited resolution so to speak. With an ODBLink adapter this is not an issue, it has a different command set that can filter individual packets, and it is in any case fast enough to eat all the car sends. You can only have one version of the app installed, but I am curious as to why you want to keep the old version?
Thank you very much for the explanation. I may have to get the ODBLink LX in that case. I'd like to keep the old version because I have a lot of old logs and I need to compare them with new logs of the same meaning in case something is missing in the new version. If however every item in the old version exists and remains the same, I'll of course discard the old one. Edit/add: apart from ODBLink LX (color green), I found an 'updated' ODBLink MX (color black). Do you think this one is better? Or ODBLink LX is enough? And I got a log file from one of my fellow who use ODBLink MX on his Model S. There are 255000 lines of data in 1118 seconds, averaging a data line every 4.4ms. Also, the 'SOC UI' and 'SOC Min' are indeed missing from his Jan. 2018 version of SMT.
AFAIK the only difference between OBDLink MX and LX is that the MX supports an additional proprietary Ford protocol, which makes no difference for Scan My Tesla. SOC UI has been removed, and several other readings have been renamed since the early releases. I can easily re-instate SOC UI and SOC Min if that makes you happy, the oher changes I will have to dig a bit for. Off the top of my head I remember renaming 'Battery Odometer' to just 'Odometer', after 1 or 2 users confirmed this reading does not change with loaner batteries, or new replaced batteries.
This is all awesome stuff! I've read the various threads on this and want to plug in as well but having difficultly finding what scanner and cable I need for my 2013 MS. If possible could you recommend the hardware needed? I read something about different pin outs? For example is this the only cable I need? Tesla CAN Diagnostic Cable (2012 - early '15) – Crimped OBD-II | eBay What OBD2 scanner do you recommend?
In that case, I'll just buy OBDLink LX. There is a Bjorn's video indicating that SOC Min is the 'real' SOC (around 00:08:20), although I'm not sure what exactly is that mean. I would like to have these parameters back in the log file since they are 'raw' data of the BMS, but they can be hidden from the phone display to make it neat. It happened to me once, about 1 minute before I arrived at my usual supercharger, the dash already displayed 0%. When I arrived, I sit there for a while before charging, took a pic of the panel and start SMT recording. Here are the pic and a part log. I estimate that the dash SOC is about -0.3% at that time, therefore the 'Usable remaining' is about 1kWh above the dash SOC. Also, it seems that SOC UI is 4kWh (the buffer?) larger than 'Usable remaining' at that time.
Yes, this is the correct cable. I think you need to message them and tell them you want to connect to CAN3 (powertrain bus). I reccommend the OBDLink LX, that is the best adapter for the money that I know of now (for this app).
Very interesting, so that means there is more you can use after car says 0%? And that 'usable' capacity maybe should be named something else... Do you think that you could drive the car further past 'usable' = 0, or do you think it is good to call it 'usable', so that regular users will not try to drive further? But I also know from Bjorns videos that the car can die at 14 km range... so I guess you can never trust the extra buffer below 0 km. If you could e-mail me that log to study, I would be very happy!
Yes, normally after the car says 0%, even when 'usable capacity' reaches 0, there is still something left. This can be verified by the pack voltage which won't telling lies like the SOC on the dash. In my log example above, the average cell voltage is 3.11V which is about 0.16V above the shutdown voltage and roughly equivalent to around 4kWh remains. Another example is from the Kmanauto's video where he continued 'driving' his car after zero mile and squeezed about 3.6kWh before stop testing. The SOC on TM-Spy screen is the same as 'SOC UI', started at 4.0% and ended at about -0.5%. I watched that video too, and I don't recommend driving pass 0 neither. However, I guess his case is the miss calculation of the SoC that sometime happened near empty especially at heavy load like pulling a trailer. At 00:01:47 of that video, the car suddenly showed 0km, which means the car found out it was wrong and corrected itself. Also at around 00:17:24 in the video, the car had been supercharged at about 56kW for about 4.5 minutes (from 17:37 on Bjorn's phone till 17:41:30 on the big screen) but the dash is still 0, which means that the car is at least 4.2kW below zero. Sure, but I cannot find you e-mail address. Just give me a PM.
So I plan on buying this cable: View the Panjo Profile page for maxwelltech And using it with the Obdlink adapter. And I plug these in behind my screen, correct?
Just drop down the shelf. It will come loose after a few progressively stronger tugs. If you have a prefacelift car be careful not to pull it out as it is hard to get back in. A coat hanger will be useful if you can't reach the cable. No need to get behind the screen unless you are rooting your car.
Just got my cables and OBDLink LX! Do I plug these in and leave them plugged in at all times or should this be only plugged in when wanting to get data?
I think the vampire drain is minimal. I would leave it in all the time and snap the tray back up even though think that is a slight security risk. Actually I bought a Y ribbon ODB2 splitter so I can have two devices connected in the center console and swap them at will while keeping the tray closed. But I don't know how well it is going to work. I am still thinking I will wire it up on the four CAN, ten wire setup.
