Just two different implementations, or the same implementation on two buses. Since most of the CANBus implementations are four wire, one bus and not ten wire, four bus.Why do you need 2 connections? What else would you attach?
I'm willing to use this software and I purchased one, but unfortunately my cheapo adapter didn't seem to work with SMT. I'll try OBDLink LX later.
My adapter is this:
https://www.amazon.com/gp/aw/d/B00QJRYMFC/
Now this LELink adapter is a bit smaller than OBDLink LX, I was able to stow the adapter and a cable inside and closed the cubby. There is some space at the bottom of the back and to your left (my car is RHD so it's on my right side though). You can't use the space at the bottom as the center console sliding door needs that space to open, so your only choice is "left wall".
Just feel the space with your fingers - the shape is odd but you should be able to put your adapter carefully in the lower part of the wall, and fold your cable on the left wall. Then make sure you can open/close the sliding door and close the cubby. Use your fingers to carefully keep the cable on the left wall. Don't force it!
iPhones support both Bluetooth and Bluetooth LE. I purchased LELink mostly for TM-Spy, but I didn't know SMT requires Bluetooth pairing.
In any case I just ordered OBDLink LX via Amazon.
Looking forward to playing with SMT!
I took it for a drive yesterday and it was still giving me crazy values that made no sense. Such as infinity consumption when I'm actually moving. I wasn't able to see a log of the values for the whole drive. I think that is a limitation of the demo version?Yes, speed = 0 sitting in your garage, so your consumption (per km) is infinity.
You can change to imperial units if you so choose in the wrench menu on the left.
I bought this adapter and it works well with the app. Looks like the odblink, but not sure if it is the same chipset.
https://www.amazon.com/gp/product/B01M19GKRP/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Wanted to thank you @amund7 for the great app! It worked with OBDLink LX in 2017 MX (RHD). Also I found that if I pair the OBDLink LX to the phone first, it also works with TM-Spy if I configure it to work with Bluetooth paired devices and enter default passcode 1234 to connect. Actually it is already paired so the passcode doesn't have to be correct.
I also was able to fit the adapter and 1ft cable inside and close the cubby.
I bought the real app. It's working much better lol.Demo version!? Ooopsie. The demo version is only playing back a dummy log, to show off the content offline. It is not connecting to your car at all. I'm afraid you will have to pony up for the real version.
Other ideas to reach the same goal is greatly appreciated, other diagnostics software or scanners that we could run alongside of?
Raw canbus data with decoded signals from other sources would also be useful.
Any packet definitions and formulas that are currently not known by Scan My Tesla would be interesting.
