Can you confirm that a full charge rated range is calculated by using nominal capacity as opposed to usable full pack? And when the battery goes below 20%, it changes it's calculation to use usable capacity instead?
Get ready to have your world rocked. The 90kwh batteries (haven't checked any others) are hiding their range degradation by giving you miles remaining based on nominal remaining from 100-80%. From 80-20%, the car slowly adjusts to use a number between nominal and usable. Then below 20%, it starts to use usable for the miles remaining calculation.
Have you noticed yet how SOC use different wh/m at different states? In other words, not all miles are created equal.
Ha, I
haven't forgotten about your question,
@supratachophobia, and have been gathering data so I'd have a decent answer with info to back it up. I had been chatting with
@amund7 about some of the readings and what to look for and how to get it and then messing with the RAW datalog and analyzing it.
I have some cursory info but haven't filled it in with the data from the past few weeks but have better data from the past month and just haven't taken the time to gather it. I wanted to take it to a 100% charge, then down to <2% charge, then back up to 100% charge and see if that made any difference on "Usable full pack" or such. I don't know if it is using a different Wh/mi for the calculation but I included that in the stats as I was curious what it was.
Here was what I had started to put together a month ago with the brief amount of info I had gathered (and it shows how behind I am on posting some of this as it is from July 8th -- oops).
These are readings with SOC at 100%, 50%, 25%, 10%, 5%, and 2% as I was wanting to see if the "Full rated range" was different at those SOC levels based on your comment about the calculation possibly being different. My calculation matched what the app / car was reporting
except for SOC of 10%.
I'd like to take readings between 25% and 5% a little more accurately and see where this different calculation occurs and if it is <20% SOC or closer to 10% SOC. Perhaps when SOC is at a low value the calculation is a little off which is why it suddenly drops from ~260 miles to 253 miles (my calculation). I took additional readings at 4%, 3%, 1%, 0%, -1%, and -2% SOC so I have that data and just need to gather it together at some point.
SOC vs "Full rated range"
- At SOC of 100%:
- Full rated range = 260 miles
- My calculation = 260 miles
- At SOC of 50%:
- At SOC of 25%:
- Full rated range = 261 miles
- At SOC of 10%:
- Full rated range = 254 miles
- My calculation = 270 miles
- At SOC of 5%:
- Full rated range = 263 miles
- My calculation = 263 miles
- At SOC of 2%:
- Full rated range = 253 miles
- My calculation = 254 miles
SOC vs "Wh/mi"
- At SOC of 100%:
- Nominal full pack = 288.8 Wh/mi
- Usable remaining = 273.5 Wh/mi
- At SOC of 50%:
- Nominal full pack = 288.5 Wh/mi
- Usable remaining = 273.1 Wh/mi
- At SOC of 25%:
- Usable remaining = 273.8 Wh/mi
- At SOC of 10%:
- Nominal full pack = 273.0 Wh/mi
- Usable remaining = 259.2 Wh/mi
- At SOC of 5%:
- Nominal full pack = 284.6 Wh/mi
- Usable remaining = 269.4 Wh/mi
- At SOC of 2%:
- Nominal full pack = 295.1 Wh/mi
- Usable remaining = 279.3 Wh/mi
