I'm debating on whether or not to add a bit more solar to my existing setup this year (still 26% credit).
We do have an EV and 2x Powerwalls already.
When I get pushed off of TOU-D-A my rates will jump quite a bit per year:
@cr0ntab how big is your system currently? I have a 40 panels 12kw system and my current TOU-D-A is $300 something a year. My new rates would be $1000 to $1200 a year very similar to yours. However, my current energy credit is over -$1600 which is $1000 more than yours. So I am thinking, adding more panels won't get your a much cheaper rates after the switch.
I have a 10.89 kW DC system. (33x 330W panels)
I'm not sure how SCE calculates these values, as my current bills show that I actually don't have any energy credits.
My guess is that it goes off of a full year TOU cycle.
My current cycle ends in June, so we'll see if the numbers drastically change.
I am currently grandfathered into the TOU-D-A rate plan, which seems to be a great plan for solar customers as the on-peak time is between 2pm-8pm, as opposed to the newer TOU plans that have peak times starting at 4/5pm. I just placed the order for Tesla Solar +PowerWall and would like to know if I can stay on my current TOU plan, or if SCE will force-convert me into the newer plans? I am hoping they let me stay on TOU-D-A until the 2022 sunset date.
Thank you for your insight. I am having second thoughts/doubts about how much this will help me reduce my monthly SCE bill (12 month average of $135, ranging between $900-$220). How effective will my 4.08 kW panels + 1 powerwall system be? Can the panels fully charge the PW every day and still be able to power the house (or feed to the grid)? Also, during the peak rate time, can the PW use its 13.5kWh to power the house AND also feed to the grid to make use of the peak rates? Is there an online calculator that can help me learn more and find that sweet spot for my home? Maybe I need to add 1 or 2 panels to get there, but I have now way to know that now. I have received Telsa's layout document but I am sitting on it for now.You will be forced to switch to the new TOU rate plans once you get PTO (Permission To Operate) for your new system. Since you are getting Powerwalls, the TOU-D-PRIME rate will be the best choice for you.
Ah I’m on TOU-D-Prime (for EV). You should consider switching to thatMy summer weekday peak rate is .75c. I’m still on TOU-D-A. So those rates have increased quite a bit as well.
My net was -$595 or so last year (not refunded, but my total usage for 2021). This year we will see, but my NBC’s have gone up about $10 per month charging two MY. But only about 10-20% on either one each night. So not a ton of driving.Ah I’m on TOU-D-Prime (for EV). You should consider switching to that
I see. Since you’re on solar, TOU-D-PRIME wouldn’t be available to you, right?My net was -$595 or so last year (not refunded, but my total usage for 2021). This year we will see, but my NBC’s have gone up about $10 per month charging two MY. But only about 10-20% on either one each night. So not a ton of driving.
I don’t think that would disqualify me, but based on their estimates it would be the most expensive plan.I see. Since you’re on solar, TOU-D-PRIME wouldn’t be available to you, right?
Good to know. I guess the difference is solar generation sell-back. The more expensive rate during peak solar generation hour actually works in your favor?I don’t think that would disqualify me, but based on their estimates it would be the most expensive plan.
I miss ToU D-AI don’t think that would disqualify me, but based on their estimates it would be the most expensive plan.
Yep. The nice part is during summer with expensive rates I generate .75c per kw from 2-5pm. Then at night I charge for just .19c/kw and get three for one (generate one kw during peak and use three during super off peak for charging and practically break even). Only cost are the NBC’s which so far has been about $10 a month.Good to know. I guess the difference is solar generation sell-back. The more expensive rate during peak solar generation hour actually works in your favor?
