Scent Wedge Thoughts ?
Discussion in 'Model 3' started by tfraley, Jun 20, 2019.
  1. tfraley
    tfraley Member
    Los angeles
    Hey guys,
    What do you think of Scent wedge?
    Kind of a cool idea, Not many scents to chose from.
    Anyone try dripping some other types of oil or anything onto them and reusing it?
  2. travis1906
    travis1906 Member
    Haymarket, VA
    I did buy a set. Was not impressed. Advertising and website over promised and under delivered. They kept coming out and the scent did not last long at all. Directions could have much better also on optimal usage. Won’t buy again.
  3. Bill Foster
    Bill Foster Member
    Nashville
    Keep your car clean and you don’t need fake scents.
  4. tfraley
    tfraley Member
    Los angeles
    Thanks
  5. cusman
    cusman Member
    Fort Worth, TX
    I felt like the car produced a smell (even though cabin is kept clean) anytime it has been parked out in the heat and then you come to it and it puts the AC (on auto) into rapid cooling mode.
    Saw Scent Wedge as a potential solution so decided to give it a try. Got the one called "The Summit". The kit comes with 4 and you are supposed to use 2 at a time (one for drive and one for passenger side). The installation was super trivial and the results have been very pleasing. I have two in backup for whenever the 1st set stops performing.
    I like the scent, and I no longer sense any smell even as the car has been in heat and is getting rapid cooled. I only put it in about 1 week ago, so I don't know how long the benefit will last, but so far very good.
    Also, they plant a tree for each kit you purchase, so I don't mind the cost.
  6. Lucky13
    Lucky13 Member
    San Mateo, CA
    Absolute garbage. Same results as everyone else. Kept flying out and even right out of the bag didn't have much smell. GARBAGE.
  7. joebruin77
    joebruin77 Member
    Encino, CA
    If you keep your car clean and still have unwanted odors, you can try this product. It’s an air purifier machine for the car
    Autowit Fresh Mini Car Air Purifier, Car Ionizer Air Cleaner
  8. ibGeek
    ibGeek Member
    Northern California
    Personally they are too expensive and don't last long enough. Put on a little cologne and become the car freshener, you'll save a lot of money and time. :)
