Schedule Time to Charge
Discussion in 'Model S: Battery & Charging' started by Soolim, Aug 2, 2015.
  1. Soolim
    Soolim Member
    Vancouver, BC, Canada
    #1 Soolim, Aug 2, 2015
    I wished MS Schedule Time to Charge will have an option that considers the departure time. That is, one programs the time to leave home, and the car will start charging the battery to the set charge limit at the right time so that the car is ready to leave. I think that the car conditions the battery temperature during charging, and it would be nice to drive when the battery is still at its right temperature. Too early charging means the battery is charge but has cooled off so that it needs to be reconditioned again.
    But short of that, I made a spreadsheet to calc the charging time based on my normal driving schedule. The spreadsheet is attached.
    View attachment Time to charge miles.xls
  2. jeffro01
    jeffro01 Active Member
    Teller County CO
    If they'd just steal the implementation used on the Volt, that's be a great start... The scheduling software there is top notch...
    Jeff
  3. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    Seconded. This would be great for a range charge where you want it to sit at 100% for as little time as possible. Tell the car you're leaving at 9:30 and it'll hand you 100% at precisely 9:30. That would be nice.
  4. 1101011
    1101011 Proud TSLA/SCTY shareholder since 2013.
    Ohio
    Especially in the winter, when you'd like to have a warm battery and warm car.
  5. Khatsalano
    Khatsalano Member
    San Mateo, CA
    The Chevy Volt has this function.
    Too bad that UI is a pain to work with. I sometimes drive Volts for work and I just don't bother anymore with that interface.
    - K
  6. gnxs
    gnxs Member
    South Florida
    My wife's Focus EV has the functionality too. She always leaves home with a nice warm car/battery in the Winter.
  7. gordo
    gordo Member
    So I developed a bash script that does exactly this and it runs on my wireless router every night when I go to bed. It has different target SOCs for weekdays and weekends. When I go on vacation or need to make a specific change, I simply log into the router's web UI and modify the target SOC.
    I asked a few months back if anyone was interested in a service or small device that would do this, but didn't see much of a response...
  8. Soolim
    Soolim Member
    did you make the small device?
  9. beeeerock
    beeeerock Active Member
    Kamloops BC Canada
    Can you expand a little on how your script accomplishes this?
  10. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    You could do this with VisibleTesla daily commands too.
  11. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    You can use pytesla to write a python script that does this as well. It should be fairly trivial. I used it to pull stats off of my car to dump into Splunk and it was straightforward.
    nside/pytesla · GitHub
  12. Ulmo
    Ulmo Active Member
    Vienna Woods, Aptos, California
    ohmman,
    I am trying Splunk now, but I might have a mental block against understanding anything in web form; I'm used to understanding things from text file editing. I poked at it for a really long time, but it is very difficult to understand. I haven't gotten anything working, and I have no idea how to approach it or look for log files.
    Can someone please give an example of how to configure Splunk to pull down Tesla API data for cars and batteries?
    I would especially appreciate any type of text file configuration system rather than the web portal Splunk presented.
    Thank you.
