Yes, it is odd because the scheduling window appears to let you set a departure time but then it doesn't appear on the main display like it does if you have off-peak rates activated. However as I posted earlier, you can get around it by setting the end of off-peak rates later than your departure time so that charging ends at your departure time.
I now have an unusual configuration - I set a scheduled departure then changed the selection to use a scheduled charging start time. The car starts charging at the scheduled time, but then the HVAC also comes on prior to the scheduled departure time even though that mode is not currently active. Anyone else seen this happen?
I solved my problem - there's a Schedule button on the Climate Control screen that I never noticed before. If this was introduced with a software update, I didn't see it mentioned in any release notes. It looks like you can now schedule charging to start at a fixed time and also schedule pre-heating separately from the Climate Control screen. What's interesting about this is that the Climate Control configuration is linked to driver profile. So, you can pre-select a driver profile when parking the car and the corresponding heating/cooling schedule will then be activated. This way, you could have a dummy profile that would be used for afternoon departures, weekends, etc. Your personal profile and its last HVAC settings will be activated when you enter the car and you can adjust the heating/cooling manually from that point.
Do you know how many electrical companies there are in the US? How is the car going to interface the with the different antiquated systems to get the proper information? It's not like the power companies provide an API that Tesla can just tap in to. I know you said wall connectors but wall connectors are just that, wall connectors. Even third party wall connectors most of them have really basic onboard "computers". They just provide power and provide scheduling. What's easier, have the owner schedule their own start charging time or built this complicated software system to have the car talk to the power company to find out the off-peak start time...
I wasn't very clear in that post, apparently. I'm not talking about having the wall connector connect to the power company's database. I'm talking about the user having the ability to tell the wall connector at what times it is to charge the vehicle, according to when the rate reductions are in effect. The user would have to get that information from the power company, and then tell the power connector at what times to charge the vehicle. It wouldn't be too hard to program a user interface that would allow a user to access the wall power connector via a web page to input what date, times, and even the rate that is in effect during those times. The wall connector could then report at what times it charged the car, how much energy it used, and what rate should have been in effect during those times, according to the information entered by the user. So just to reiterate... this would be something that the end user sets up, not the power company.
