Huh, OK, yep, that looks like it's set right, so my assumption was off. Another question then: what is it that you're seeing that says it's charging? Sometimes people see the pulsing green on the charge port and always think that means it's charging, but they may not realize that if the door is open, and the heat is on, it will be drawing that energy through the plug connection, even though it's not really "charging" because it's scheduled for later.
Having major issues replaying on this thread and app. Sorry. I'm working on it.
will display car will charge
If that schedule is set properly, then when you put the plug into it, the car's screen should show a message that says something like Charginis scheduled for 12:00 AM. It doesn't show that? Also, I mentioned it earlier, but you put that setting in the profiles while its plugged in, right?
Yes allprofallprofil
Yes the car
If that schedule is set properly, then when you put the plug into it, the car's screen should show a message that says something like Charging is scheduled for 12:00 AM. It doesn't show that? Also, I mentioned it earlier, but you put that setting in the profiles while it was plugged in, right?
