Scheduled Departure Charges Prematurely
tsimon
3
0
South Carolina
I have Scheduled Departure set to 6:00 AM but the care begins charging shortly after I plugin at home around 6:00 PM. Scheduled Departure was working fine prior to Tesla pushing a firmware update on my Wall Charger. I now have a new Wall Charger and it is still doing this. I read that it might be a location issue so I have done several soft resets and still have the issue. Any assistance would be great.
Skione65
1,453
716
Kentucky
This has unfortunately been a known issue. Apparently Tesla is aware and just is not interested in fixing it. Too busy working in FSD I guess!:D It apparently is trying to take care of TOU rates, which I don’t have so it’s absolutely of no benefit. My work around as well as most others? Set your desired charge amount, ie. 90%, hit done, let it start charging, look at the amount of time required to charge to completion at that percentage, then set the clock time to start charging at that point and you’ll be done for departure. Pretty accurate for me.
One caveat......if your trip charging to 100% just account for slight tapering. Ie maybe add a half hour or 45 minutes as taper last couple percent is sloooooooooow. Best of Luck.
Ski
Schulmann
22
25
Blainville
Same problem here, scheduled departure is not working “perfectly”. Tesla charges at any time mainly when I plug it it. I dont know if it is because of winter. This is not an issue since the most important is to have the battery and habitacle warm for the departure time. And this is something challenging because on 240v/32A there is not enough energy to do it in a short time in cold (-5 C) . Tesla needs 3.5kwh to heat stator + 5kwh to heat habitacle + 0.8kwh to 12v battery. So the idea by starting well in advance the charging process and “over charging” by 3-4% the battery, is to be ready for departure. When I can I prefer to set the start time of the charging then 15 min before leaving I hit “pre conditionning”. PreConditionming works perfectly usually I can get the battery close to 20C, Scheduled departure is viable sometimes the battery only reaches 10C. Thus in cold weather it is better to Supercharge at tbe end of a trip then in the morning before leaving.
Reactions: tsimon
jdcollins5
755
489
Wilmington, NC
From what I understand, Schedule Departure does an initial charging check to determine the charging rate in order to determine when to schedule the charge start in order to be complete by 6:00 AM.
eprosenx
2,065
2,481
Beaverton, OR
Ski
Yeah, Tesla is trying to be “nice to the grid” here by finishing its charging by 6am (so it does not hit the grid during “morning warmup”), but this frankly pisses me off. I am not on TOU pricing and I have a lightly loaded 200a service on a transformer with plenty of capacity in a neighborhood heated by natural gas.
I want my damned car to finish charging right at the time I set it to such that it has the maximum retained battery warmth for my drive to work.
I get that Tesla wants to make the feature super simple to use and to be “nice” to the grid (not be blamed for outages or requiring power companies to upgrade), but frankly it should not be up to Tesla to decide when to charge my car. (FWIW I don’t want to have to manually set a charge rate every day - this is what we have computers for)
Padelford
391
361
Seattle
How did you get a firmware update to your wall charger? I wasn’t aware that was possible.
rincewind
482
259
London England
I had this issue last week, and it's not connected to tesla trying to save the grid. I was sat in the car at 10am, and set the scheduled departure for 6pm (18:00 hours on the spinner). The car started charging straight away, and continued charging for over two hours until it reached the set 100%. Then, later in the day, I monitored the car and it did absolutely nothing, so when I departed the cabin temp was at 6 degrees and the battery was cold - almost a full dotted line on the regen.
It's broken, properly.
Gasaraki
1,374
939
Syracuse, NY
OK everyone, here's how the scheduled departure works. You set it to 6am, but you come home at 6pm and it start charging! Why? This is normal.
The car will charge and check how long it takes to charge your battery based on the power level coming in to the car. If the power coming in to the car is steady at 11KW for example, the car will stop charging then start up again based on how long it thinks it takes to charge it to the level you set it at.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
If you have a gen 3 wall connector and it is connected to wifi, it should be able to download firmware updates. If you have a gen 2 wall connector, it can update the firmware automatically if the car receives an update and the wall connector is plugged in.
Reactions: Phlier
Feb 10, 2021
15
23
Charlotte, NC
I tried Scheduled Departure for the first time last night. Same problems as others. What I found was that I had to toggle the off-peak charging time screen and then it worked. (Even though, we don't have off-peak rates here in Charlotte.) You'll know it is properly set when you see a blue scheduled departure box with your selected time on the main charging screen. If you selected preconditioning, it also shows up on the climate screen once it is set.
Padelford
391
361
Seattle
I’ve never seen a notification that the charger firmware was being updated. I probably have a Gen 2 charger, as I don’t recall any info about it having WiFi capability.
