We have a long (700+ km) trip to do today.
So yesterday i charged the car with our "free" solar, it reached 95% before the solar panel could not deliver enough power to continue.
No problem, i will just set the departure time to 8am and then it will be ready.
Just got up, it's 20 past 7 in the morning, and i just popped into the app, expecting the car to have started charging the battery to 100%.
But this has not happened, the car is connected to a 3.6Kw charger so it can not do 5% in less than an hour.
What's even more strange is, the only option i have in the app and on screen in the car is to "release charge port".
I tried turning the departure setting off, unplugging and replugging the charger, and i even tried rebooting the car, but i only get the option to release the charge port, not to charge. (Not even manually can i start a charge right now)
I have offcourse set the charge limit to 100% yesterday, befores starting to charge from the solar panels.
From what i read, the setting should make sure the car and the battery is prewarmed for the journey and the battery is topped up to the charge limit i set, so i now fear, that the car will start warming up the battery, using the battery itself, and when we depart we will be left with even less than 95%
Not a massive problem, i know that this will only be a minute or 2 extra at a SC when we go to charge the car, but still, either something is "broken" or the function does not work as i expected it to.
PS. the charger says "Car connected, waiting for car signal" which it always does when the car is connected, but does not demand a charge.
PPS. While writing this, the car just started heating the battery, and the charger has been activated and the car now draws 16Amps (Max) so it is not draining the battery atleast, i just do not understand why it will not charge the battery and just now, it stopped heating the battery, i assume this means that the battery is now at operating temperature, and the charger is now idling again, instead of charging the battery.
Bonus info : temperature outside right now is 5C (41F), if this matters ?
