I've just had 36.2.1 installed and have played with the scheduled departure a little. It seems a bit lame to me. Here is what the release note says:
So, a few points based just on this info:
1. Charging will stop at 6am, whatever time you set (aka hard coded !!!). What?
2. Assuming you set departure at 6am or earlier, you'll get cabin preconditioning + charge. You can't separate them.
3. In order to ensure charging completes just before 6am, I'm guessing that the car will throttle charging to a lower rate.
From using the feature, I've also gleaned this:
4. It doesn't seem you can have scheduled departure and scheduled start running at the same time. I was playing around last night at about 9:30 pm and set a scheduled departure time for 7am. As soon as I plugged the car in, it started charging immediately - even though I'd previously set a scheduled start at midnight.
5. It plays around with the max charge rate. When it started charging at 9:30pm, it was throttled at 12A - I guess that's the rate it needed from 9:30pm to 6:00am to get the car to 85% (the limit I'd set).
Now, there's an interesting question here. What is the strategy for the start time? It seems to me that it could either:
- Start immediately and restrict the charge rate to finish at the scheduled time.
- Start as late as possible, knowing the max charge rate available, so that it's done by the scheduled time.
The latter approach would need the car to "sample" the max rate available (maybe that's what it was doing at 9:30 when I was fiddling with it?). But that won't reliably work if (like me), your charger ramps up the charge over a few minutes, unless the car waits long enough. But how long is long enough?
All-in-all, I'm of the view that this new feature is at best very poorly explained with a confusing UI, but at worst is actually pretty badly thought out!
Scheduled Departure
It's now easier to have your car comfortable and ready to drive with Schedule Departure. For any location (e.g. Home), plug in your car and select a time for when you want your car to be ready to drive. Once your specified time is set, the car will schedule charging to complete before peak electricity rates begin (6AM) to reduce energy costs and ensure consistent regenerative braking and performance. It also automatically starts climate control so the cabin is comfortable at the set departure time.
To enable Scheduled Departure for the current location, go to Charging > Schedule. Then select DEPART AT and set the departure time, choosing whether you'd like Scheduled Departure to apply ALL WEEK or only on the WEEKDAYS. If ALL WEEK is selected, you have the option to "Precondition Cabin on Weekdays Only" by selecting the checkbox.
Note: Scheduled Departure will not precondition your car if it has less than 20% battery remaining. This feature improves and replaces the setting previous called Smart Preconditioning.
