Scrapped off a little piece on the underside of my model 3. Do you think this is a concern or just cosmetic damage that can be repaired with some glue? Suggestions?
View attachment 738940View attachment 738941Scrapped off a little piece on the underside of my model 3. Do you think this is a concern or just cosmetic damage that can be repaired with some glue? Suggestions?
That's the aero shield. You can just glue or tape it back. It's not structural, all it's there for is to smooth the airflow and prevent debris from entering the bottom of the car.
You did also scratch up the metal piece underneath, but not sure what that is connected to.
If you decide to glue it, use a flexible glue with a tenacious hold. I’m a big fan of polyurethane glues like “Shoe Goo” or “Household Goop”. They dry to a texture similar to silicone sealants, but unlike silicone they stick forever, and I haven’t found anything yet that they don’t stick to.
I concur with @Frank99, a contact cement like Shoe Goo should work pretty well and be easy enough. Just wipe some on both parts with your finger and then press it up into place - it'll stick immediately. And if you can't, won't, or fail to fix it, it's no big deal to have that small hole there. Water and air go up in there anyway.
The scratched metal is the sway bar so there's no harm done. It's an indestructible solid steel bar.
If you are asking, you probably would want to pay someone to do it for you.
Any tire shop or an independent wrench will get the install done in 15-30 minutes max. Might charge your for full hour, though.
Read some forums on here about the aero shield damage and people getting it replaced from Tesla at no charge. Tried to attempt the same and Tesla said they’d charge me $198 for it and will not be covered under warranty since it is physical damage
Maybe some people got lucky and had it covered under good will or the shield broke apart without an obvious collision, but for your case it's obviously a collision, so would be something insurance would cover, not a warranty.
Shoe Goo seemed more like rubber cement than contact cement. Worked for gluing rubber things like rubber shoe soles... but less well to glue the shoe sole to a non-rubber part of the shoe.
