Nobody answered the original question yet. Am I too picky or shall I make a big deal out of the fact that they twice......../QUOTE]
You are definetly not being too picky. The SC needs to fix this bothersome crooked steering wheel issue. Might there be a meticulous, competent, and patient alignment tech from another SC that can be sent over to Orlando to fix your very frustrating issue?
Thanks for all the input guys.You are not too picky, that SC is just too sloppy. My car has had alignment issues since new, and they have yet to be fixed.
Nobody answered the original question yet. Am I too picky or shall I make a big deal out of the fact that they twice and knowingly delivered a car, which is under warranty, with a crooked wheel?
I would love to if I get my $262.50 backMaybe it's time to try a dedicated alignment shop?
The problem is not using the level on the steering wheel, it's getting the steering wheel centered while unloading all the suspensions parts/bushings/tires. Otherwise they've got the wheel centered and everything else on the car crooked, and then they do the alignment, and as soon as the car pulls out it's wrong again.
Basically, they don't know how to do their jobs.
edit - I always run into these problems anytime I need a wheel balance or alignment. If someone ever asks me to do a optional one I always say NO, because it can only get worse than whatever it is now. So every shop sends the wrench monkey who just started to go use a $40k machine, how could he get it wrong, right? The machine will just do it... Uhm, no.
, perhaps about .5 - 1 degree.
Hope my ramblings help everyone understand things a little more.
This pretty much nails it. Tesla gets the alignment so it's in spec, and they are so busy that they rush through things. Jumping from car to car is very common, which in turn causes all of the problems they have been having.A few things to add, been doing alignments for 15 years. First is the wheel should be centered before any adjustments are made and if it is and then rechecked after the adjustment is done there should not be a problem. I have had my fair share of wheels off center after alignments and had to re set up the car on the rack and re adjust. The biggest problem is that most younger techs these days just get thought to "put it in the green" or with in the tolerances. This is ok and yes the car is " in spec" however to make a car drive straight and like it should you have to set the car up to have the same measure side to side, sometimes making an adjustment for road crown with a slight difference in camber. The hunter equipment that is used by tesla is great if used correctly which is often not done.
If I were to take my car into someone for an alignment I would ask that the car be set up with the measurements being the same side to side, this along with a few extra steps at the end of the alignment to ensure the wheel is straight will make any car drive better than new. I too got my car with a slightly off center wheel, and I aligned it myself to correct.
To the OP, I would just ask that they re adjust you car and check the side to side measurements as close to equal as possible.
To the people talking about tech comp, tesla does indeed pay there techs by the hour, however they are all judged on how efficient they are. Most other shops do pay there techs based on how much work they do, most good techs make good money with this system, which also means the tech does not get paid to fix his mistakes it come backs. So anyone who is good will stick with the traditional system, and techs that can't make it seek a job that does not use that system. I am not saying tesla hires bad techs, just saying they are not competitive for the most experanced techs in the industry.
It's being off whole degrees, that bothers me. I have a digital level that reads in tenths. Half a degree goes by really fast. Maybe it's more than that, for you? At the tie-rods, such a correction may only be 1/10th of a turn.
