Seeking Advice: Use of Model 3 as Trickle Charger for LEAF
SageBrush
REJECT Fascism
May 7, 2015
12,085
14,993
New Mexico
The LEAF 12v battery will not self discharge as long as the LEAF is *not* plugged in. Its a known defect of the LEAF BMS that it won't top off the 12v battery if the car is left plugged in. Simply unplug the LEAF and it will maintain the 12v battery just fine. The LEAF has almost non existent vampire drain, so it can be left unplugged for extended periods of time.
Thanks for the confirmation.
I think though that it is more correct to say the problem exists if the car is plugged in and not charging
Morhydro
123
62
Scotland
See JP White's post below
Wonder if that depends on the modfel of LEAF? Ours is a Gen 1.5 - the 24kWh with Heat Pump version built in 2014. It is plugged in all the time, has done 52,000 miles. Has been left for extended periods. Never had a problem with the 12V battery.
Wennfred
2,915
1,821
San Diego
2013 Nissan Leaf was a bad year for 12 volt batteries out of Tennessee. When I went on vacation, I would connect a battery tender to the 12 volt battery. Never had a problem with my 12 volt battery on my 2011 Leaf. Battery tender on Amazon around $30.00
Fred
qdeathstar
2,004
1,577
VB
Agreed.
And by the same logic, a subway ticket will get you to work for $3 so it is not a great idea to use $50k car to get to work either.
You also shouldn't plug your phone into the car to charge either. It would be silly to use a $50k car to charge your phone when you can buy a phone charging battery pack for $25.
It’s different logic bro
