But the main question is, why didn't I get 40K mi on these tires? Why'd they wear out so fast? I don't drive particularly hard, pretty gentle most of the time in fact. But I was hoping for longer range. If the tires are warranted for 40K+ do I have grounds for contacting Michelin about these tires?
The normal reasons are alignment and pressure. Hard to tell without an inspection of the the tires. New roads and the aggregate used in the roads also makes a difference.
My last set of Primacies lasted over 40K miles and would have done better if the alignment had been better. I've found that alignments at the Service Centre are hit and miss. Use an alignment place that specializes in race cars or a frame repair shop--check that they have a good reputation with the locals--because the alignment technicians there actually understand alignment rather than just reading the numbers off the machine. I had one alignment tech (not at an SC) that thought the only thing alignment did was prevent the car from pulling. You can't even have a conversation with that type of tech because after everything I said he kept asking which way the car pulled.
