Self Built Spare Tire Compartment
rsusi
25
15
Virginia
Purchased a spare tire from Amazon along with a scissor jack. Put the spare in the rear cargo hold and built a compartment to hold tire and kit. Built the compartment out of plywood and then covered it with matching black carpet. Looks as if it came from the factory. Still have room for groceries and other items. Two items behind tire are on the back of the rear seats which are folded. Rear seats can either be down or up with no interference of tire compartment.
NHK X
759
616
PNW
Cursory look on amazon not showing anything that can handle the weight nor fit the diameter needed. Looks like mostly spares made for a Kia Soul...
Reactions: P85_DA
NHK X
759
616
PNW
Have you had need to use a spare?
I actually have and it was incredibly inconvenient (poor timing right before a business trip), local shop didn’t have the right size ect.. ended up paying a lot to get a summer tire manually driven over by the tire shop employee and had my wheel damaged by their machine. Purchased another tire to match my all seasons.
I went through this ordeal because I couldn’t have Tesla flatbed the car to a service center since I was flying out that night.
All that said to say, I completely understand why the OP is doing this. . When I looked for ways to mitigate this in the future I couldn’t find a spare wheel that supported the weight of the car, besides another large tire. Hence my concerns with the OPs set up.
Amp Dup
123
81
Orange County, California
I just got a tire kit from Modern Spare. I tried it out and it worked pretty good. (I'm guessing it's the same tire rsusi got from Amazon) It's pretty beefy for a donut spare. It is limited to 50 MPH. Driving at low speeds, I couldn't tell it was there. It has an adapter hub that mounts to the Tesla hub. If you have one and imagine changing it yourself, I highly recommend practicing in your driveway!
Reactions: X-pilot and P85_DA
boelkers
131
119
Minnesota
Check out the storage in the 5 Seat Model X:
Thank you for the pictures. I'd been looking at getting that spare but couldn't find any pictures with a MX actually using it. Having been stranded before in the middle of nowhere on a road trip with no cell signal and a flat tire on my MX and after getting towed to the nearest town have Tesla Roadside saying I was SoL is no fun. This spare would at least get me back on the road and closer to a service center.
Musterion
18h 03m 37s −24° 23′ 12″
Jan 10, 2013
579
168
M8
You positive the spare can handle the weight of the x?
Not sure about the Amazon one, but the ModernSpare tire has 115 load rating (2679 lbs.) which exceeds the stock wheels. I calculate it has about 1” smaller overall height (diameter), so Pi” smaller circumference, which is manageable. If the wheel itself is certified to sufficiently high load, it looks like a good option for temporary spare.
Daisame
434
195
Sicklerville NJ
Thanks for posting. I always figured roadside assistance would be sufficient for me, but I am planning on driving down to FL for the holidays, so maybe this is a good option for the open highway.
I have ever only had one flat tire in about the last 30 years. I figure the overall chance is very low, at least it has been in my case. I am not sure if I want to spend money on something I may never need for a single trip, but I will have to give it some thought.
Amp Dup
123
81
Geez! I've had probably 5 flats in the last 20 years. 3 of them were unrepairable. Most recently was in the Model X:
No goop and air compressor was gonna work here! There was no mounted spare in the Tesla system. We were headed out of town to a wedding and had to get flatbedded back home and took the Honda to the wedding. (The spare wouldn't have been a good choice to continue to the wedding but might have saved some time.)
Reactions: X-pilot
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
No offense intended, but that Modern Spare on that X looks like those old cartoons where the driver stuck a wooden crutch on a missing wheel. The one where the back of the vehicle hops along picking up the crutch and moving it forward and down again.
Reactions: boaterva
BabyGerald
New Member
Oct 3, 2020
Oakland, CA
Was the adapter hub required? From Modern Spare's website it sounds more like the hub is only required for vehicles with the performance package that has the larger rear brake calipers.
Modern Spare's website has been updated to state that ALL new MXs (2020) have the larger rear brake calipers and will require the adapter.
sacfan
183
74
Sacramento
The hub is absolutely required. The bolt pattern on the spare wheel is not the same as the Tesla wheel.
Are you sure this is correct, because the ModernSpare will fit on the front with no adapter. The adapter may only be necessary on the rear of the Model X (2019).
