Like this ... Tesla Aero Wheel Rim
To my knowledge, the aero rim was neither lighter nor narrower than the base 19's.
I like the i3's approach to a larger diameter, narrower rim/tire...though not quite to that degree.
You need the instagram app. It's still a private account brcause the designs are not ready yet. Search for Xtraero in the app and request to followLink please!
I am really intrigued by what a set of i3 equivalent rims would do on an S. When you see the range hit for the larger rims on the S/X, it just seems like 15% is a reasonable estimate going from the 19" to a narrower, lighter, more aero, lower rolling resistance option.
How do you change your tire - or put air in it?I always liked the idea of the 'pizza pan' wheels to get a little more range. There are many ways to increase range and increase efficiency. Adding pizza disks to the wheels seemed like a very inexpensive way to get about 4-6% (depending on what source you believe and what speed you are driving at) more range.
The Moon disk people wanted $150 for each disk plus $700 to create a mold and they would need a wheel shipped to them. Kind of defeated the idea of keeping it simple and inexpensive. So I found some pizza pans on Amazon, drilled 5 holes into the rim and attached them. I know many will cringe at the thought of putting holes into their rims, but I don't really care. So far I have done only the front wheels as a test and see if any issues come up. Once it all goes well and I have all 4 wheels I will do a test to see how much of a difference it makes.
Here is a photo of the disk. Everyone that saw it thought it actually looked good.
You can see my aero wheel designs at instagram account Xtraero. I welcome your feedback on the designs[/QUOT
Ditto.....link pleaseLink please!
Update from Mike:
Mooneyes.com can spin the size you need. We have none.
Hubcap Mike.Com
MOON Discs
these are about as aero-as-you-can-get!
..screw-on tho ?! eek
David, what if your disks were instead installed between the rims and the brake rotors, flush with the backside of the spokes?
The discs would have holes that fit the lug patten and just slide over the lugs.
Do you think you could get near the same efficiency gains with none of the problems? You could also paint the discs black to maintain near stock cosmetics.
My disk were custom made by Mooneyes. Just go back in this discussion where I explained it. They require custom lug nuts to attach the disks without drilling into the rims (which was my first solution).
Do you think you could get near the same efficiency gains with none of the problems? .
That's one advantage of my complicated louvered wheel idea. Sitting still and at low speeds it looks like a normal spoked wheel.
At high speeds it is flush, but its all a blur anyway, so you can't tell.
Can you guys tell me why you think covering the spokes on the outside would be meaningfully different than covering the spokes on the inside? In both cases, the spokes are exposed to flowing air on one side.
Neat. I have the old style 5-spoke 19" rims though. There are a lot of us out here with these so if you make any for this rim please post. How do they attach? I think they look great. Did you do any testing to see what range improvement you expect?I have created a wheel cover for the Model S Turbine wheels, they are not cheap to make but they fit on the wheels with no modification to the wheel. Not sure if anyone is still checking this thread so I will be brief for now. If you have any questions please let me know. Here is a picture.
