Lets agree to disagree. I wouldn't drill, not into rims, not into into lugs, only into the pan.Re Fracture Points: Doubt an 1/8in shallow hole drilled on centerline of spoke at the thickest part of the casting will amount to much. Fondle a rim yourself to appreciate.
@JRP - the pans are way off the lug bolts, centerbore or the central part of the spokes.
By the way, I have read of a case where a wheel flew off of the car, even though all the lug nuts were still bolted on. Stress fractures, most likely caused by using the wrong tools to tighten the lug nuts, possibly caused by over-tightening the lug nuts with the correct tools, caused all the lug nut heads to shear.
I'm sure they do as SpaceX prints their rocket engines. Affordable is another story.Speaking of 3D, do printers come 20in wide?
@WarpedOne - Have a closeup of those plastic straps or a link? They add a thickness that might fit into the clearance that my pans offer. But the natural tensioning would be lost.
From another TMC thread today:
Nice pan job!
Racing stripe(s) up to wheel well, same color as pans, might be easy to do and also tie it all together.
Could be viewed as a feature. Anything that adhered to the disposable sticky wouldn't end up on the rims.One problem is that the area that is not in contact with the rim would be sticky and gather crud, but probably not more than a dusting.
