In case anybody's X was having the same issue.
Basically if you walk from the front of the car the door opens a few inches and should open fully when you walk pass the door. My vin is 46xxx and it hasn't worked since day one. But my SC has finally figure it out and here is the description from the repair sheet. Hope this helps!
Concern: Customer: my left front power door does not self-open to the correct angle.
Corrections: Module - Ultrasonic Door Sensors - LH
Verified customers concern. ultrasonic door sensor was found to be faulty. Ultrasonic door
sensor was removed and replaced.
Corrections: Carrier - Sensor - Ultrasonic - Rear Door - LH
Ultrasonic sensor carrier was removed and replaced.
Part Quantity
ASY, SENSOR CARRIER W/ADHESIVES, LEFT (1075447-00-C) 1
SENSOR, ULTRASONIC, RADIAL,COUPLING TAPE (1055890-00-E) 1
Parts Replaced or Added
Part Quantity
