nwdiver
I just don't see it viable for long distances or on the thousands of miles of 2 lane highways that semis travel every day
Why would it work for trains but not trucks?
The trucks will have to travel a lot slower than they do now. If you don't keep contact with the gantry you will get arcing which is bad for the equipment and may affect the performance of the truck. Then you have weather. Ice and Snow will affect charging with the gantry and the Ice and Snow may block the equipment on the truck from connecting to the gantry. The issues affecting train overhead charging will most likely also be an issue with overhead semi charging. Such as wind deflection and corrosion. The ganteries will have higher maintenance costs. Who would be in charge of maintaining the gantries the state or the power companies?
The catenary wire isn't stationary: it gets moved around by trains and by the wind.The point where the pantograph of an electric train makes contact with the trolley wire creates one of the most complex and challenging environments for rail component manufacturers and test engineers to understand, let alone predict and improve.
For trains to operate efficiently, the pantograph must maintain constant contact with trolley wires suspended from catenary systems. Yet these wires and their support structures exhibit different vertical stiffnesses along any given section. The catenary system zigzags in 30 to 100 meter intervals to prevent grooving. The force the pantograph applies to the wire must stay within a well-defined range (70N to 120N). If it is too low, loss of contact results in arcing, which not only causes the train to lose power but damages the trolley wire and the contact bar through etching and overheating. If the force is too high, the resulting friction wears down the wire and contact bar prematurely.
Delivering the right amount of force requires variable vertical motion. But when trains move at higher speeds, pantographs lose their ability to react appropriately. Even when the trolley wire is as flat as possible, it is only flat when it hangs undisturbed. When the pantograph lifts the wire, the resulting deformation creates a wave. If there is too much uplift, the pantograph creates a much larger waveform that causes contact problems for the next pantograph coming down the line.
In general, when a pantograph runs underneath the catenary, it sets up a wave-like disturbance which travels down the wire with a speed determined by the tension in the wire and its mass per unit length. When a train approaches this critical speed, the pantograph catches up with the disturbance, resulting in dangerously large vertical displacements of the wire as well as contact interruptions. The top speed of the train is then limited by the critical speed of the catenary. This problem was central to the test runs, since it was desired to test set 325 at speeds well above the critical speed of standard TGV catenary. Also feeder stations will most likely be needed It looks like the cost per highway mile would run around 5 million per mile.
This is false and shows that either you haven't done even basic research or you're purposely spreading misinformation.
So what you're saying is that Tesla, who knows more about EV's than any other company, hasn't run the numbers and is actively building a product which will fail.
This has all been covered and proven not to be significant over the life of the vehicle. Not to mention that EV's can and are already be powered from renewable sources. Basically you're putting out the same FUD talking points we've heard over a decade about EV's.
I'm certainly not attempting to spread false info. That number came from a google search. Googling again I get a slightly lower number. If you have another source that you feel is more accurate, please post it.
It's false because it does not take 40.7kWh, or 38kWh, to equal 1 gallon of diesel. Internal combustion is highly inefficient and you don't get anywhere near 40kWh of energy going to the wheels. You might get 30% where and electric motor/inverter is closer to 95%. You'd get better efficiency using CNG in a combined cycle generating plant to charge an EV. Also there is no zero emission CNG engine, they still produce CO2, even if they somehow manage to not produce any other combustion byproducts. You also ignore the many leaks along the entire CNG infrastructure which release methane, a highly potent greenhouse gas.It takes 40.7 KwH to equal 1 gallon of diesel.
And yet you are very proficient at it.I'm certainly not attempting to spread false info.
You are quoting from an article from 2017. Do you realize how fast battery technology is advancing in energy density? The semis are going to be using a battery format and energy density that is still a bit out ahead of their cars that they have now, which are five years newer than that article. But in general principle, yes, of course--liquid fuel itself is always going to be much more energy dense than batteries. So now about how it's used:carrying 38 kilowatt hours of energy in every gallon — 27 times {more space dense than} that of lithium ion batteries" ***
Heh, this is one of the more deceitful statements of comparison I have seen in a while. You are comparing a hypothetical, on-paper, ideal highest possible value for diesel engines as a straight across equivalent comparison as if it is the same as a fairly mid to low end value of real electric motors in use today. While not being a lie, it is certainly an attempt to mislead.Worth noting here is that a diesel engine maxes out around 60% efficiency where-as an electric motor is around 85% efficient.
Excuse me the &%#$ outta here?! Underperforming in what way? The 500-600 mile range is sufficient for some routes, probably not all yet. Not having to bog down traffic to 45 mph on those long uphills and getting to recover energy instead of wasting it on downhills are both benefits to real use. Less maintenance = less downtime = less lost revenue. That's overperforming. There are a mix of some pro and con factors. We haven't heard much specifics on the actual weight levels yet, so cargo tradeoff may come into this some--still need to see that. I'm not stating that it's flat-out better in all respects, but your absolute term "underperforming" is bias and opinion--not fact.just a single underperforming EV Semi/ Class 8 truck
And again, you are stating nonsensical futuristic predictions as if they are fact. The weights are not well known yet, but probably will not be several tons difference.be several tons lighter than EVs,
Sorry, but I can't give you the benefit of the doubt on this one. It's just a straight-up "pants on fire" LIE. The Tesla semi prices are not even as high as $200K. Yet you are saying that these magical CNG semis are going to cost $200K LESS than that!! So they will have negative prices, and the companies are going to have to pay people to take them? Try again, pal.cost $200K+ less to purchase
CNG cheaper than electricity per mile? Hmm, that may be a close one, with CNG being usually cheaper than diesel fuel. Electricity can be generated from so many sources, and solar electricity is getting SO cheap that it's getting hard for anything to compare with that. (Large volume utility electricity generation contracts are getting to less than 2 cents per kWh). But now your earlier complaints about fuel density are going to come back to bite you. CNG also can't store as much onboard, because it has low energy density versus those liquid fuels, so CNG is going to have some of those tradeoff problems with lower range, etc. Let's call it a push on this issue for now.cost less to refuel
HA HA HA HAAA HAAAAAAAA!! Ah, no. No, you haven't. You say you have seen data from some EV trucks. OK, sure. And then you laughably state that it is the same thing Tesla is using in theirs. Haa ha! No, Tesla is developing their own custom, proprietary battery chemistry and cells and packs that other companies do not have access to.I've seen the actual numbers (payload loss, useable range, cost) from actual EV Class 8 trucks (not Teslas mind you) that use the same battery technology that the Tesla Semi has access to, it is totally inadequate. Like it isn't even close.
I see you gave yourself the out to claim you win no matter what, by saying "exclusively". Well, that obviously can't happen, because they only have a few prototypes, but their business requires hundreds of semi trucks. So no, of course they don't have enough of them to cover their entire company's trucking needs. But in the spirit of what you claimed, they have already proven that to what you asked. They have been using those prototype trucks to deliver parts back and forth between their factories in California and in Sparks, NV. And yes, they have been delivering their cars with them too. So that is the "eating your own dog food" that you claimed would convince you, but we know it won't change your mind, because you have convinced yourself that it isn't possible.I'll be convinced, when Tesla requires Tesla Semis to be used exclusively to deliver Teslas, build their factories, deliver their parts, etc. That would be a good indicator, to me of their competitive TCO.
Wow.
I was pretty sure diesel engines were not yet to 50% efficiency yet, so I Googled some for it, and I was correct. This is from an article on Cummins working on their "Super Truck" R&D program. They were barely able to get to 50% in this advanced prototype, but most trucks are about 43%.
“We learned a significant amount in the SuperTruck program,” said Wayne Eckerle, Vice President of Corporate Research & Technology for Cummins, a self-described “combustion guy.” “It gave us the chance to demonstrate the feasibility of several advanced engine technologies that we’d been working on previously and integrate them into an operating system.”
The resulting SuperTruck powertrain achieved the DOE’s target goal of a peak diesel engine system brake thermal efficiency of 50%. “That wasn’t at all easy,” he stressed, noting that “diesels today are probably 43% efficient.”
Cummins aims to boost heavy-duty diesel efficiency to 55%
The Energy Department recently awarded Cummins, the nation’s only independent diesel engine maker, a two-year, $4.5-million grant to boost its previous mark by 5 percentage points to 55% brake thermal efficiency.www.sae.org
Tesla Semi: Price, release date, and rivals for all-electric truck
Tesla plans to launch its first all-electric truck, the Semi. The new electric vehicle will continue CEO Elon Musk's goal of shifting the world to clean energy.www.inverse.com
Taking Daimler trucks, for example, the phrase "isn't even close" is applicable there. Their attempts at electric semis are WAY behind Tesla. Daimler's head of trucking didn't even believe Tesla's specs, because he didn't think it was possible what they have achieved:
“If Tesla really delivers on this promise, we’ll obviously buy two trucks — one to take apart and one to test because if that happens, something has passed us by. But for now, the same laws of physics apply in Germany and in California.”
Tesla Semi defies laws of physics and is passing us by if true, says Daimler's head of trucks
Daimler has several electric truck programs in the works and today it revealed the latest progress on the eActros heavy-duty electric trucks....electrek.co
I’m genuinely curious to see how Tesla treats it’s business customers.Will tesla cut charging speeds on trucks that charge multiple times a day
Can they top Volvos treatment? They chartered a private jet to take our CEO and CFO to Virginia to tour the factory and introduce the new Volvo VNL truckLower number of customers and with greater influence has to mean better service.
