Sensors in doors and trunk are much more sensitive after 17.26.76
Discussion in 'Model X' started by johnschlemmer, Jul 16, 2017.
Tags:
  1. johnschlemmer
    johnschlemmer Member
    San Ramon
    Has anybody noticed that, after the latest update, the sensors on the doors and trunk seem much touchier and keep an even greater distance between objects that they detect? I used to be able to open the falcon wing doors in my garage, and now I can’t. Same with the trunk - I used to be able to open it all the way, but now I’ve learned (after hitting my head on the half-opened trunk a few times) that doors don’t open nearly as far as they used to. There’s a huge amount of space it leaves now and it’s quite annoying. Is anybody else experiencing this? Is there a way for service to adjust how much space the sensors leave when detecting objects? Never thought such a small change in sensor sensitivity would make things significantly less convenient for me, especially with the doors in the garage.
  2. ninefiveone
    ninefiveone Member
    SF Bay Area
    Are you sure the "open doors fully in this location" checkbox didn't get unchecked when you got the update?
  3. johnschlemmer
    San Ramon
    Positive. That check box doesn’t seem to completely override the sensors. And the trunk wouldn’t have changed from that either.
  4. dragonxt
    dragonxt Active Member
    Bay Area
    Sensors seem the same to me.
  5. ninefiveone
    ninefiveone Member
    SF Bay Area
    Trunk is tied into the same roof sensor the FWDs use and as far as I know that's the only sensor the trunk uses. Hence if the trunk thinks it can't open all the way, it has to be the roof sensor telling it not to. So either your roof sensor happened to go wonky with the update (unlikely) or there's something off about the way it's using the roof sensor data.
    I may be totally off on your problem but these firmware updates do funky things to settings. Sometimes if you un-toggle a setting, open things, and then re-toggle it, things work properly again. Won't take you more than a couple of clicks and a few minutes of time to try it.
  6. vandacca
    vandacca ReActive Member
    Hamilton
    Try rebooting your main center console screen (hold down thumbwheels). If that doesn't work, make sure there isn't any bird droppings on your roof sensors.
  7. DrivingRockies
    US
    I'm seeing the same thing. Much more conservative in their opening.
  8. outie
    outie Active Member
    SoCal
    Now you mention it, yes. My passenger side FWD used to open higher inside my garage. Now it doesn't open as high.
  9. Evil.Labrat
    Evil.Labrat Member
    US/Utah
    Exactly the same for us.
