Sentry Mode breaking stuff
Jul 2, 2019
6
Phoenix, AZ
Hey folks,
Long time lurker, first time poster.
I have had my model 3 since end of December 2018, and I have been to the Tesla dealership so many times I can tell you in the exact order in which they've changed the signs outside of the bathroom, so I'd like to have to not go (again) and break this once+ a month habit.
My current issue just started yesterday: I have Cruise Control/Auto Pilot, and I use SanDisk Extreme Go USB 3.1 Flash Drive 128GB (SDCZ800-128G-G46) for recording; I use Sentry Mode at my work/other places, but when I'm home, I have it off as I have a garage I park in. Both yesterday and today, I go to work (Tesla works fine), park, Sentry mode comes on, I work, then when I go to leave, my headlights are stuck "on" in auto mode (it's 4 PM, sun is out, confirmed lights go off if I choose off but come back on back in Auto mode), my car acts as if I don't have CC/AP ("cruise control is unavailable", no lane lines, no other cars showing up, view is zoomed in over my car, etc), and my AC takes 20+ minutes to finally start cooling down (I live in Phx, AZ so you can imagine how much this sucks).
I contacted Tesla Customer Service yesterday, and they said "the engineers have found that having Sentry Mode turned on is causing some issues. What they are suggesting is: Turn off Sentry mode. Remove USB drive. Allow car to sleep. Autopilot features will return after a sleep cycle." I complete this process, drive in today works great. Drive home, same thing as yesterday.
I've removed the USB and am going to do the same thing to fix my car again as I did last night, but I wanted to see if anyone was experiencing the same issues? I don't want to have to do this every night, so tomorrow I'm going to turn off Sentry mode at my work and see if it makes a difference.
bill_5r
New Member
May 21, 2019
3
4
Gilbert, AZ
Same thing happened to me today, first time I have had any issues. All I had to do to get everything back was exit the car and let it lock and then get back in and everything came back. Car was showing 165 degs interior temperature before I used the app to turn the AC on, was thinking that may have had something to do with it.
OCR1
3,754
4,099
Southern California
What version of software are you running?
I would try removing the USB flash drive completely for a couple of days just to see if your issues are really related to the drive being in place. Is cabin overheat protection on? The car must be getting very hot while you are at work.
Jul 2, 2019
6
Phoenix, AZ
I ended up leaving Sentry Mode on but not running, same thing happened on Wednesday. I went into the controls, turned Sentry Mode off, my headlights came back on, cars on the side started appearing, etc. Turned Sentry Mode back on, everything was still working. I left my USB plugged in the entire time, so it does appear to be directly related to Sentry Mode.
I don't use Cabin Overheat Protection because it really drains my battery, only tested in 90s degree weather, it's now 110 so will be worse, I probably wouldn't make it home if I had it on.
As for the version I'm on, I always update when a release is done, current version is 2019.20.4.2
