Sentry Mode Catches Hit in Parking Lot
Discussion in 'Model 3: User Interface' started by CCIE, Mar 29, 2019.
  1. whatthe2
    whatthe2 Active Member
    Denver, CO
    I didn’t bother looking at any of the events since I had no damage. But, sure enough, it filled up.
  2. brkaus
    brkaus Well-Known Member
    Austin, TX
    Cars driving by in the parking lot are “motion” and thus detectable events.
  3. DiamondHills
    DiamondHills New Member
    Diamond Bar
    Does sentry mode constantly record when the car is parked, or by motion only?
  4. Need
    Need Active Member
    SoCal
    If it is on, it constantly records (just like dashcam) to the 1 hour buffer. When it detects movement around the car, it will save off the 10 min clips.
  5. Knightshade
    Knightshade Well-Known Member
    NC
    To clarify-
    Sentry never records. Anything. Ever.
    Dashcam does.
    All sentry does is, if it goes to alert state, move the last 10 minutes of dashcam footage to the sentry folder.... (plus flash the lights, put up the HAL warning, etc).
    This is why you can turn on Sentry even without a USB device. It does all the same stuff except the "move the dashcam footage" step.... and then the additional stuff if it goes to alarm state (loud music, alert on the app, etc)
    And it's why if you turn off dashcam you get no sentry footage.
  6. Silicon Desert
    Silicon Desert Active Member
    Sparks Nevada / GF 1
    Generally agree. The wife had an interesting thought about this. While yes it might give more proof of fault, in some cases that proof of fault might show intentional road rage causing an accident and prove that the other party is mostly at fault instead of shared fault, which of course increases the amount of a claim (resulting in more money to attorneys). She quoted a couple of cases where that was the outcome. However, I am a fan of dashcams and we have them in all cars.
  7. texas_star_TM3
    Texas
    the rear sensors are a lot less sensitive than the front sensors... if i back into the parking spot at work - every movement on the parking lot triggers Sentry....even people just walking by several feet away... if i park with the back out - i have no alerts and you literally have to touch the car to trigger sentry... something to consider
  8. srs5694
    srs5694 Active Member
    Woonsocket, RI
    Umm... No, unless you're splitting hairs....
    Fundamentally, TeslaCam and Sentry Mode are the same thing. The main difference is that the former operates when the car is driving whereas the latter operates when it's parked. There are differences in what triggers a recording to be saved, what's displayed on the center screen, etc., but in terms of recording data from the car's cameras, they work the same.
    If Sentry Mode "never records. Anything. Ever" (your words), then "mov[ing] the last 10 minutes of dashcam footage" would be impossible.
    Both Sentry Mode and TeslaCam record continuously (with a caveat you note below), creating a 1-hour (IIRC) set of recordings in 1-minute increments. Once that 1-hour buffer is full, the car begins deleting the older recordings in order to make room for new ones. When Sentry Mode is active and the computer thinks something suspicious is happening, the car moves the most recent ten minutes of footage from the rolling 1-hour buffer into a permanent storage location so that it won't be overridden. The same thing happens when you're driving with TeslaCam active and hit the button to save a recording (or sound the horn, with recent software versions and if you've activated that feature). Note also that Sentry Mode has two types of alert states in which recordings are saved. The first ("alert mode") just displays the HAL message, in addition to saving recordings. The second-stage alert is called an "alarm," and it flashes lights and blares music very loudly. The Model 3 owner's manual covers all of this in more detail.
    If the car had not been recording continuously, then it would not be able to save recordings of the ten minutes of activity leading up to a trigger event.
    This is correct; it is possible to activate Sentry Mode without a USB drive. The result is that the HAL display will appear on an alert and the lights and music will appear on an alarm, but of course there's no recorded footage.
    Are you sure about this? I thought the two features could be activated and de-activated independently of one another, despite the fact that they rely on the same underlying functions. I don't see any mention in the owner's manual of a requirement to activate TeslaCam before Sentry Mode can be used, although of course this is something that might not be mentioned there, or I could have overlooked it.
    • Disagree x 2
  9. Knightshade
    NC
    Or dealing in facts.
    No they aren't. At all.
    Dashcam records camera footage. Sentry never does.
    Dashcam requires a USB recording device. Sentry does not.
    As just 2 of the most obvious examples.
    This is fundamentally wrong.
    The dashcam icon appears even when parked. And remains on (unless you manually turn it off or remove the storage media) as long as the car is awake.
    Because that's the feature that records video.
    The sentry icon appears when parked, regardless of having storage or recording anything at all, so long as you have the sentry feature enabled for that location.
    Only in the sense it's the dashcam feature always doing the recording, and never sentry.
    Which is what I originally said.
    And your owners manual says too.
    That is complete nonsense.
    Moving an already-recorded (by dashcam) file to another place on the drive has nothing to do with recording anything.
    So again sentry never records anything
    Recording is not part of sentry at all.
    Moving files Dashcam recorded is though- if you have dashcam on and a storage device attached.
    No, they really don't.
    Dashcam records.
    Sentry does not. Ever.
    • Disagree x 1
  10. srs5694
    Woonsocket, RI
    I see. You're defining "Sentry Mode" differently than I (and Tesla) do, to move its video-recording feature (a key feature, by most peoples' reckoning, I think) outside of the scope of what Sentry Mode does. By your definition, you're probably correct, but I disagree with your definition, and I think most people would, too.
    • Disagree x 1
  11. Knightshade
    NC
    Nope.
    I'm pointing out how the car actually works.
    If you turn off dashcam (the camera icon) then nothing is ever recorded to your USB storage.
    Regardless of having sentry turned on.
    Because sentry does not record anything. Ever. Dashcam does.
    Not sure how you're confused on this. You can test it yourself.
    Turn off dashcam. Leave sentry on.
    See if it records anything after turning dashcam off, no matter how many times you make it go to alert.
    (spoiler- it won't)
    because as I'm pointing out, sentry doesn't HAVE a video recording feature.
    Dashcam does.
    Sentry leverages that fact in a couple of ways:
    1) It keeps the car awake. Meaning, as Tesla explains to you and I cited to you from the user manual, Dashcam will keep recording.
    2) It moves the last 10 minutes of dashcam recorded files to the sentry folder if it alerts.
    What sentry never does is record anything on it's own. Which again you can confirm by leaving Sentry on, but turning dashcam off.
    Nothing further gets recorded in this state.
    Dashcam does.
    • Disagree x 1
